2004 XJR with violent front shake
Old Sep 24, 2016 | 09:34 PM
joeleerj's Avatar
Smile 2004 XJR with violent front shake
Hell all,
I've been searching past forum post regarding front end shake and have not quite found an answer. I had a slight front end shake that could be felt and seen through the steering wheel and it became worst when braking at highway speeds, also there was a grinding noise when braking at very low speed. Today I replaced the front rotors and brake pads. The noise is gone, but the shaking has become considerably worst at all speeds and very violent at speeds from about 45mph upwards. What did I do wrong? Did replacing the rotors cause an imbalance in the front end? I will take everything apart tomorrow to see if I can find the problem. I made sure that all the torques were at spec. Any help would be appreciated. Thanks
Old Sep 25, 2016 | 10:26 AM
viper1996's Avatar
Double check the obvious...Make sure the lug nuts are tight...
Old Sep 25, 2016 | 10:59 AM
joeleerj's Avatar
Thanks, I plan to recheck everything this afternoon
Old Sep 25, 2016 | 12:54 PM
joeleerj's Avatar
PROBLEM SOLVED!!
I'm feeling less like a Jaguar and more like a Jackass
Somehow a washer got lodged between the face of the rotor and the wheel.. What happen when you rush. Now to test drive.
Old Sep 26, 2016 | 09:56 AM
Sochi2014's Avatar
99% of shaking on this car under braking are worn bushings on front arms, especially at initial phase of braking. Went through this on my car.
Old Sep 26, 2016 | 04:51 PM
joeleerj's Avatar
I'm in the process of re-doing the front suspension, But this shaking was due to an assembly problem caused by me.
BNYHAN
Aug 7, 2017 12:54 AM
xjrjag
Oct 2, 2016 01:29 PM
Hafrod
Sep 19, 2016 10:57 PM
Hex Type
Aug 12, 2016 01:55 AM
smokphattys
Dec 18, 2010 07:13 PM
