2005 X350 VID Block Editor
Old Sep 26, 2023 | 05:33 PM
mcpflrb's Avatar
Default 2005 X350 VID Block Editor
Does anyone know the best way to edit the VID block on a 2005 XJR? I replaced the ECU with a used one and am trying to match the VID block VIN number with the car. I have SDD v164 and got the seed key calculator to enable VID block mode in SDD, but with that I am not seeing a way to edit it, and also don't know how to calculate the check sum for the VID block with the new VIN.
I have found numerous threads on the subject but no conclusive way to do so. Anyone know?
Old Sep 26, 2023 | 11:03 PM
xalty's Avatar
old ecm around and has comm? just download the vid go straight to vid block read on the new one and upload the old one in
if you don’t have it program the ecm as existing with the connector unplugged. when it says comms failure with the ecm and it prompts you to put the battery cable thing go hook the connector back in.
then it should use the as-built from the current session.
just keep playing around and figure it out.
Old Sep 28, 2023 | 07:07 AM
OldKarz's Avatar
I have a few versions of SDD. None will find 'As Built' for my 2004 X350 NA even though it is there in exml file. Any ideas as how to have SDD get the file?
Old Sep 28, 2023 | 08:04 AM
xalty's Avatar
you program an ecm with no block and it calculates it internally according to vcats data you entered at the start of the session 🤷‍♂️
Old Mar 24, 2024 | 07:05 AM
Aleksei's Avatar
Default Good afternoon!!
[QUOTE=mcpflrb;2681911] Кто -нибудь знает, как лучше всего отредактировать блок VID на XJR 2005 года? Я заменил ЭБУ на использованный и пытаюсь сопоставить VIN-номер блока VID с автомобилем. У меня есть SDD v164, и у меня есть калькулятор начального ключа для включения режима блока VID в SDD, но при этом я не вижу способа его редактирования, а также не знаю, как рассчитать контрольную сумму для блока VID с новым ВИН.
Я нашел множество тем на эту тему, но не нашел убедительного способа сделать это. Кто-нибудь знает?
[/QUOTE
]Good afternoon!! have you solved the problem with editing vid blok... If so, tell me how or who could help you solve this problem.. Thank you very much in advance!!!
Old Mar 24, 2024 | 07:06 AM
Aleksei's Avatar
Originally Posted by mcpflrb
DoGood afternoones anyone know the best way to edit the VID block on a 2005 XJR? I replaced the ECU with a used one and am trying to match the VID block VIN number with the car. I have SDD v164 and got the seed key calculator to enable VID block mode in SDD, but with that I am not seeing a way to edit it, and also don't know how to calculate the check sum for the VID block with the new VIN.
...Good afternoon!! have you solved the problem with editing vid blok... If so, tell me how or who could help you solve this problem.. Thank you very much in advance!!!
Ura
General Tech Help
28
Oct 29, 2024 10:39 AM
ysilvercs
E type ( XK-E )
Mar 18, 2021 08:03 PM
jeje
Mar 19, 2020 12:49 PM
JayJagJay
Dec 8, 2019 01:27 PM
Bowmanconsult
Oct 23, 2009 03:14 PM
