2005 XJR ABS Fault after front wheel hub replacement
Hey guys. My driver front wheel bearing was shot so I replaced the whole hub with the Moog 513327 from Rock Auto. No ABS issues beforehand, and now turning the car on I get an ABS fault and the ABS light. I did turn the car on twice in the install process to turn the wheel for better access to the bolts. I wouldn’t expect that to cause the issue though? I disconnected the battery for 5m, reconnected, and the light is still there. Ideas?
Inspect sensor and wiring for a fault.
Scan vehicle for a DTC and delete it if found.
If the DTC returns then you may need to replace wheel sensor.
BTW Silly question.......the new hub does have a reluctor ring?
Johnken
Nov 11, 2017 12:42 AM
Johnken
Oct 14, 2017 09:39 AM
