Is ABS/DSC light harmless like Check Engine?
Old Nov 10, 2012 | 01:43 AM
Wolfy's Avatar
Default Is ABS/DSC light harmless like Check Engine?
My Kitty just turned 100k mi and came down with an ABS Fault/DSC Not Available ailment. First I felt a hard grinding in the brakes, then the warning light came on. So, my question is -- since abs/dsc is not part of the basic brake system, can I just ignore it like a check engine light and keep driving it without causing long-term harm? Because this happened at the beginning of a trip, I was able to complete the 30mi trip and returned home safely...with the warning light on all the way.
Cheers,
Wolfy
Old Nov 10, 2012 | 05:15 AM
steveinfrance's Avatar
It is safe to drive, obviously you have no ABS.
Fixing it can be a question of cleaning the wheel sensors or mending the ABS module.
Search the Forum and you'll find lots of threads.
The CEL is trying to tell you something - it isn't a 'time for service' light, it means something's wrong and you need to read the codes and fix it.
Old Nov 10, 2012 | 10:59 AM
+1 on Steves advice, don't ignore the check engine light.
BrentGardner
29
Dec 16, 2024 12:13 AM
JeffR1
Sep 12, 2015 10:43 AM
niner nellie
Sep 1, 2015 10:53 PM
SingBlueSilver
Aug 27, 2015 02:20 PM
daro31
Aug 27, 2015 09:26 AM
