ABS Fault
Old Apr 15, 2019 | 09:47 AM
Peterinio's Avatar
Default ABS Fault
Hi. Today I am getting these faults/codes. Could this be because on Saturday I removed the spare tire pressure sensor? It didn't seem to be attached so I pulled it out. Not sure how to reattach it anyway.
Could use some help. Thanks very much.
Old Apr 15, 2019 | 10:00 AM
Highhorse's Avatar
What year and model do you have? ....that doesn't look like an X308 dash.
Old Apr 15, 2019 | 10:51 AM
Peterinio's Avatar
Sorry, I guess I hadn't mentioned that.
2009 Vanden Plas
Old Apr 15, 2019 | 11:22 AM
Highhorse's Avatar
Ok, we need to get you to the correct forum...I'll contact a mod to get you there.
Old Apr 15, 2019 | 02:44 PM
MeatBag's Avatar
I don't think it is the tire pressure sensor you removed.
I had the same code on Friday - "ABS Fault" along with "DSC Fault" and "Cruise not available."
I had my mechanic look at it, and it is the front passenger wheel speed sensor.
Your message shows that it is your rear passenger wheel speed sensor.
I saw this in another post today (Wingrider, i believe) for a pair of front hubs with the speed sensors for $75.
I bet the same place has the rears too.
Old Apr 15, 2019 | 03:40 PM
Peterinio's Avatar
Thanks, Meatbag. If that is your real name....
Old Apr 16, 2019 | 07:13 AM
MeatBag's Avatar
Rear wheel speed sensor (priced for your side of the pond) https://www.ebay.com/itm/251255771616?ul_noapp=true
Old Apr 16, 2019 | 12:30 PM
Peterinio's Avatar
Thats great! Appreciate it. Peter
R L
26
Apr 18, 2019 10:24 AM
alephzain
16
Mar 1, 2019 06:00 PM
blackonblackXtype05
Jan 11, 2017 10:45 PM
03JagSType3.0
Sep 25, 2012 08:32 PM
