ABS Fault
Hi. Today I am getting these faults/codes. Could this be because on Saturday I removed the spare tire pressure sensor? It didn't seem to be attached so I pulled it out. Not sure how to reattach it anyway.
Could use some help. Thanks very much.
I don't think it is the tire pressure sensor you removed.
I had the same code on Friday - "ABS Fault" along with "DSC Fault" and "Cruise not available."
I had my mechanic look at it, and it is the front passenger wheel speed sensor.
Your message shows that it is your rear passenger wheel speed sensor.
I saw this in another post today (Wingrider, i believe) for a pair of front hubs with the speed sensors for $75.
I bet the same place has the rears too.
Rear wheel speed sensor (priced for your side of the pond) https://www.ebay.com/itm/251255771616?ul_noapp=true
R L
26
Apr 18, 2019 10:24 AM
alephzain
16
Mar 1, 2019 06:00 PM
blackonblackXtype05
Jan 11, 2017 10:45 PM
03JagSType3.0
Sep 25, 2012 08:32 PM
steffenvh
Jan 10, 2010 11:45 PM
