ABS Module Motor Pin Fix for X350
Old Jul 12, 2015 | 05:50 PM
cybercg's Avatar
Default ABS Module Motor Pin Fix for X350
Hi,
I have an '04 XJ8 with an ABS Fault. The WDS diagnostic directs me to the front passenger wheel with a C1234. The wheel sensor checks out OK with a volt-ohm meter so I plan to replace the hub assembly complete with new wheel sensor.
In the event that the hub and sensor replacement does not correct the problem, I could be looking at an ABS Module fault.
I have successfully performed the motor pin re-solder technique on my '01 XJR to correct its ABS Fault so I am wondering if there is a similar procedure for the ABS Logic Module used on the 2004 XJ8.
If there is a procedure for the '04 ABS Logic Module, can you direct me to it?
Thanks for your help.
Old Jul 12, 2015 | 06:18 PM
34by151's Avatar
Check out this TSB
http://www.jagrepair.com/images/TSB/...%20Cluster.pdf
If you have SDD you can use this to confirm each sensor. Setup a monitor for the sensor and the spin the wheel noting the wheel rotation causes pulses on the monitor
You can do the same thing without SDD but you need a CRO to monitor the sensor input
34by151
trosty
26
Dec 18, 2022 06:40 PM
Shawn Svacha
Nov 4, 2019 02:47 PM
joey g
US Northeast
Sep 7, 2015 06:28 PM
jaguarbill
Sep 5, 2015 11:43 AM
XJsc-guy
Sep 2, 2015 11:43 AM
