ABS problem after changing main ECU
Old Sep 23, 2020 | 02:44 AM
Braq33's Avatar
Default ABS problem after changing main ECU
Gents
jaguar xj6 2006 has damged ECU due to water leakage.
Main ECU has been changed with new one EEPROM moved from old ECU to new one.
car started normally but it's not accelerating.
Battery is good with voltage more than 12
I hooked charger to the battery and give me green sign in SDD offline mode v131.
found U300-55 ABS DTC.
I tried to program ECU to fix ABS problem but it give me no communication with audio and REM modules.
Programming failed.
I dumped XTML file from ECU found ABS data different from the actual.
I pulled ABS fuse number 20 under gloves box car worked fine it's accelerating and change gears normally.
I tried to find ABS Module programming in jlr couldn't find.
​from which section you program ABS in jlr.
AND what is the procedure to program ABS with moongose 131 jlr?
THANKS
U300-55 ABS DTC description
ABS actual serial number
ABS serial number in ECU
Braq33
Sep 21, 2020 07:56 AM
van883
Sep 10, 2017 09:43 AM
Greg
XJ40 ( XJ81 )
Aug 4, 2015 11:35 PM
narsaboy
Audio/Visual Electronics
Jun 16, 2009 01:52 PM
briggsaln
Aug 9, 2008 12:48 PM
