abs sensors
Old Dec 26, 2016 | 07:37 AM
fingers's Avatar
Default abs sensors
had abs light and dsc not available come up as soon as i set off, cleaned all sensors and rear reluctor rings and its still on , can anyone tell me the abs resistance value of the sensors, both the front are 535 and the rears are 509 and 504,
many thanks
2003 x350 3L petrol
Old Dec 26, 2016 | 08:51 AM
JagV8's Avatar
It normally looks for a pulse train not really the resistance.
Old Dec 26, 2016 | 09:57 AM
motorcarman's Avatar
Fault codes are a much more efficient way to diagnose/repair than random parts replacement. More likely a harness fault in the sensor circuit but...........
You need to read the DTCs.
bob
Old Dec 27, 2016 | 04:17 AM
fingers's Avatar
so here is the story, i have sdd 131 with mongoose pro and have used it many times for dtc codes but when i got the dreaded transmission surge i used it to reflash the transmission and ended up bricking the car and had to have new gem and ecu and so i am a bit reluctant to use it anymore although if im not reflashing anything and only using it for trouble code diagnosis i would have thought it would be safe enough
Old Dec 27, 2016 | 11:17 AM
paydase's Avatar
If you use SDD just to read and clear DTC's, il should not harm
