ABS and TRAC lights on
Old May 19, 2009 | 10:19 AM
FrankF's Avatar
Default ABS and TRAC lights on
Hi, At first it was sporadic, but now when I start my car, the ABS and TRAC message is on. I am fairly certain that my wheel sensors need to be cleaned since I have tried peeling out with my car and traction control stops it, plus I have jammed on my brakes and ABS kicks in. Any thoughts on how to clean these or should I go to jaguar to fix. Does anyone have experience with this or am I wrong in my assumptions?
thanks,
Old May 19, 2009 | 03:54 PM
ken@britishparts.com's Avatar
Not a bad place to start. You may want to try a local Jag shop and see if they can read the codes.
Old May 24, 2009 | 05:54 PM
jag_genius's Avatar
either needs a wheel speed link harness in the front or a module rebuild .. or battery is going
Jpav27
Jul 31, 2022 06:43 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
redrover41
23
Sep 25, 2015 01:33 PM
avern1
Sep 8, 2015 06:25 PM
innzane
Sep 2, 2015 10:08 AM
