Adding GPS System
Old Feb 22, 2009 | 02:01 PM
vaclone's Avatar
Default Adding GPS System
I am looking at an '04 XJ8 that has almost all of the features I am looking for except the navigation system. How easy/expensive would it be to get one installed? Any recommendations? Thanks.
VACLONE
Old Feb 22, 2009 | 04:33 PM
twotone's Avatar
I suggest going with an aftermarket portable GPS (Tom Tom, Garmin, etc.) rather than trying to install an OME one. Less expensive, easier to upgrade maps and you can take it from car to car.
Just my thoughts,
Twotone
Old Feb 22, 2009 | 05:08 PM
bmw745ion19s's Avatar
it would be very expensive try $5k + and very time consuming, bottom line= if you want navigation ( i wouldnt buy one without it, esp for resale purposes) wait until you find one with it!
Old Feb 23, 2009 | 02:45 PM
veffremov's Avatar
The buildin nav is not all that great. Can't find a simple POI like closest post office.
Also it costs a small fortune to upgrade the maps. Get a decent aftermarket unit and you will be much better off.
Old Feb 23, 2009 | 03:17 PM
hlgeorge's Avatar
Go for the aftermarket one. I have a GPS in my XKR and it is only good for the clock. My Garmin is online updatable and I really like the fact that your destination can be programmed into it before you get to the car.
Old Feb 23, 2009 | 04:26 PM
timfountain's Avatar
There is a lack of clarity in some of the information posted above.
I have no axe to grind, but the Nav DVD is $199 from Navteq. Not cheap but not exactly 'a small fortune' as suggested by veffremov.
Also hlgeorge says the nav in his XKR is only good for the clock, but bear in mind he doesn't have the Denso Nav fitted to most modern Jags, he has the older Alpine which is not great (assuming he is accurate in his tag line which states he has on 01 XKR).
The nav fitted to the 04+ XJ8/S/S-Type is a fine nav and the integration with all the other vehicle functions (climate, phone etc) is excellent and the nav itself is very useable....
- Tim
Old Feb 23, 2009 | 04:58 PM
the only problem i have with the system is the graphics quality compared to my BMW and other flagship models...however it is a Jaguar and being british, i dont expect its electronic graphics to be the same :P Overall i still think its a great, easy to use system, it could add more street names though
Forcedair1
Feb 19, 2020 01:51 PM
XF_Hunter
Jan 17, 2018 08:38 PM
jdzubas
Oct 4, 2015 09:14 AM
jehart49
Sep 12, 2015 05:36 PM
Corycarlo
Sep 5, 2015 11:41 AM
