Air Bag Code 15 + Dead Rear LH Window + Passenger Door Warning
Old Oct 15, 2019 | 09:08 AM
Khello's Avatar
Default Air Bag Code 15 + Dead Rear LH Window + Passenger Door Warning
Hello,
2005 Super V8, 95,XXX miles. Sat in the garage for a month while I was on travel and battery died. Replaced the battery and now I'm getting Air Bag Code 15 (C1414 RCM and OCS don't match??), a dead rear LH window when using either switch, and a Passenger Door Open warning that will not go away. I have verified the following:
- Window 25 Amp fuse (location F28 in turnk fuse box) was good.
- Door was shut securly
- Ground terminals both battery and vehicle ends are tight and corrosion free.
- Zero outsanding recalls on Jaguar and NHTS websites
I'm thinking there's a connector somewhere that needs cleaning. Any input on where to look in this 17 ft long car is greatly appreciated.
WRPDRYV
Dec 7, 2017 02:47 AM
russ&sue
Mar 23, 2016 03:38 AM
Volbrewer
Jun 23, 2015 08:54 PM
Martin
Mar 2, 2014 06:33 PM
walt_00XKRConv
Aug 16, 2010 07:46 PM
