Air Suspenders (Again!)
Old Dec 31, 2013 | 03:41 AM
norrimac's Avatar
Default Air Suspenders (Again!)
Sorry all, I just joined a week ago and diligently read a MASSIVE thread about air suspension.
Went to investigate my car... and now I can't find the thread again! So:
1998 XJ-R V8. The suspension works but it's rock-hard, appears to be level though. Warning light says there's a suspension fault. (It's in German!)
According to the thread I was following, it may just be a relay. So I downloaded couple of manuals, but neither mention which relay it might be.
The thread said (I think) a nē4. There appear to be 2 possible relay culprits.
Any ideas where to go from here?
Thanks in advance,
Norm.
Attached Thumbnails Air Suspenders (Again!)-jag1.jpg   Air Suspenders (Again!)-jag2.jpg
Old Dec 31, 2013 | 07:40 AM
reyesl's Avatar
Welcome to the Forum!
I made an attempt to locate a Fuse/Relay diagram for your 1998 MY XJR and found none, will be searching on Captain Jaguar's site next. You might have more results if your request was posted in the X308 section (1997 - 2003 MY).
Old Dec 31, 2013 | 08:35 AM
reyesl's Avatar
Checked the Electrical Guide and could not locate any reference to suspension relays.
Attached Thumbnails Air Suspenders (Again!)-elec-guide.png   Air Suspenders (Again!)-engine-comp-relays.png   Air Suspenders (Again!)-front-relays.png   Air Suspenders (Again!)-left-side-relays.png   Air Suspenders (Again!)-lhd-control-module-relays.png
Air Suspenders (Again!)-relays.png   Air Suspenders (Again!)-rh-heelboard-relays.png   Air Suspenders (Again!)-rhd-relays.png   Air Suspenders (Again!)-trunk-relays.png   Air Suspenders (Again!)-adaptive-damping-controls.png
Old Dec 31, 2013 | 09:51 AM
Fraser Mitchell's Avatar
Thanks in advance,
Norm.
Hi Norm
Air suspension was only fitted to the X350 cars which came out in 2003. Your 1998 XJR is on steel coils. Of course you may have a defective shock absorber. Your XJ-R probably has CATS, and the system has detected open-circuit on one of the shocks. You should see an electrical connection to the shocks. Try unplugging and replugging each connection, as it may have corrosion. If CATS detects a fault, the shocks will go to HARD setting, which is the default.
Old Jan 1, 2014 | 06:06 AM
norrimac's Avatar
reyesl, you're a gent! Even tho' it's not the solution, very kind.
Many thanks. (Happy New Year!)
Old Jan 1, 2014 | 06:08 AM
norrimac's Avatar
Fraser,
Well, that's a relief/revelation!!!
I'll give it a try and let you know. Good New Year to you! Thanks.
Norm.
Old Jan 18, 2014 | 07:47 AM
norrimac's Avatar
Guys, how do you reach the top of the back shocks to check the connector? Is it back seat removal time?
Thanks,
Norm
Old Jan 19, 2014 | 06:47 AM
reyesl's Avatar
1. Remove the "Boot Floor Panel"
2. Remove the 2 "Side Panels"
3. Remove the black "Foam Protective Covers" on top of the shock mounts.
Attached Thumbnails Air Suspenders (Again!)-rear-shock-mount-l.jpg   Air Suspenders (Again!)-rear-shock-mount-r.jpg
Old Jan 20, 2014 | 05:50 AM
norrimac's Avatar
Not only a scholar but a gentleman to boot! (Sorry - trunk).
Many thanks.
Old Jan 20, 2014 | 12:35 PM
norrimac's Avatar
Hmmm... nope, that's not what I'm seeing. I removed the panels as suggested, but it would appear that the shock top is in a turret below the rear parcel shelf in my car.
Many thanks for the suggestion, all the same.
Old Jan 21, 2014 | 02:25 AM
reyesl's Avatar
Sorry, wrong MY in my post.. 2004 instead of your 1998.
scooternva
29
Mar 25, 2025 12:45 PM
scooternva
19
Oct 27, 2015 02:14 PM
mel
Sep 20, 2015 04:56 PM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
lordpeterk
Sep 6, 2015 01:50 PM
