Air Suspension
Old Dec 5, 2017 | 04:33 AM
PaulJJoubert's Avatar
Default Air Suspension
2005 Jaguar XJ8 Sovereign
The car displays a VEHICLE TOO LOW fault in the message center. The scan shows a PLAUSIBILITY error. Checked all the fuses. Replaced the relay(R1) and the compressor. The fault remains, the compressor does not function.
I spent close to 6,000 euro at Bradleys in Galway proir to this, problem disappered for about 2 weeks and then started appearing intermittently again.
I would appreciated any assistance as to what to do next.
Paul J Joubert
Old Dec 5, 2017 | 06:49 AM
Fraser Mitchell's Avatar
You seem to have spent an awful lot of money on something that is normally fairly easy to diagnose and fix.
Normally a "Reservoir plausibility error" relates to the compressor wearing out, but could also be telling you there is a leak somewhere.
I have attached the DTC codes for the chassis
File Type: pdf
Old Dec 6, 2017 | 11:27 AM
electechbw's Avatar
Do you mean that the compressor is not running or not producing air pressure?
Old Dec 6, 2017 | 03:43 PM
Default Air Compressor
The air compressor does not run.
Old Dec 6, 2017 | 04:10 PM
platinummaker's Avatar
Just had enough of similar replacement of individual parts wearing out in system. Just popped a grand for some Strutmaster coilovers. I’ll report back on the results as I think I’ll be putting them on this weekend.
Old Dec 6, 2017 | 04:57 PM
electechbw's Avatar
Paul,
If you compressor isn't running and you have replaced the compressor and relay, then the next logical steps would be:
1. Check fuse F6.
2. Make sure you have a good connection from your compressor to ground. Make sure pin one of your air suspension relay socket goes to ground as well.
3. Connect 12 volts to pin 5 of your air suspension relay socket to see if your compressor turns on.
Old Dec 7, 2017 | 12:50 PM
Lagonia's Avatar
I have been running Strutmasters coil-overs for the past year with no issues. I must not be a suspension connoisseur because I could not detect any appreciable differences from air to coil overs.
Old Dec 8, 2017 | 03:40 AM
Love to hear that. Thanks
Don B
General Tech Help
17
Aug 8, 2017 09:11 AM
Branbeezy
21
Oct 22, 2016 06:26 PM
tweetybird
Oct 17, 2016 03:18 AM
MickJagguar
Oct 4, 2016 04:26 PM
JimC64
Feb 13, 2014 07:35 PM
