Air Suspension Problem
Old Jul 21, 2016 | 06:20 AM
MooSSe's Avatar
Default Air Suspension Problem
My 2004 VDP has both left front and left rear tires all the way up in the wheel wells. Both passenger side tires look to be at normal height. Compressor is not coming on and there is NO ride height or air system messages. I checked both fuses in the trunk and they are fine. Compressor is about 6yrs old, both front air shocks are about yrs old, and right rear is 1yr old. Left rear is original. Any suggestions on what to look at next?
Old Jul 21, 2016 | 10:01 AM
clifton94's Avatar
Have you tried driving it a little way see if the compressor kicks in also was anything done prior to this happening
Old Jul 21, 2016 | 05:21 PM
MooSSe's Avatar
Yes, my wife actually drove it that way all day even though I told her not to. I'm going to get codes read tomorrow to see if that points me at the problem.
Old Jul 22, 2016 | 03:48 AM
clifton94's Avatar
Have you checked the power at the fuses there might not have blown but have no power to the fuse terminals also there is a relay in the front power distribution box might be worth checking
Old Jul 22, 2016 | 03:01 PM
Don B's Avatar
The relay in the front engine bay fuse box is R1, which controls the air compressor.
Cheers,
Don
altownsend
Jan 20, 2018 10:43 AM
Bhpbug
May 3, 2016 12:26 PM
Exterior
Nov 14, 2006 12:23 AM
Nov 5, 2006 12:00 PM
May 25, 2006 07:31 PM
