Air suspension trouble
Air suspension trouble - very high ride
Hi all
This is my first post, apart from the presentation, on this fabulous forum.
I have a 2003 XJ6 which has developed an air suspension error. I was on a somewhat lengthy drive when suddenly "Air suspension fault" appeared in the display and the ride got very coarse/hard. When I stepped out of the car I could see the rear had raised, probably closer to 2 inches/10 cm.
When I arrived at home I ran diagnostics (iCarsoft LR II) and it said I had a short circuit in the rear left shock (I can't remember the code). I swapped the relay and the error disappeared. When I put the (most probably) faulty relay back in I got a different error saying the relay was bad. I know have a new relay in place but the back of the car is still very high and I still have a C2302 Leveling plausibility error.
Also the car is about 3/4" lower on the left side, both front and rear.
I have recorded the height of the car today and will be checking tomorrow if there's any change.
Could it be the compressor, or should I look elsewhere? Any tips would be appreciated. Thanks.
Hi all
Compressor normally throws C2303 Reservoir plausibility error. No matter what code you get for suspension issues, the ASM always sets the shocks to "Hard" hence your hard ride. It does sound as if you might have something wrong in the leveling equipment, like a duff height detector or something. Early cars had one height detector per wheel, but later ones had one for the front pair and one each for the rear wheels. Has anything been done to the car recently, or anything happened that might have caused damage to the detectors and their wiring ?
Mine is an early model with 4 height sensors/detectors.
I did have the shocks out to replace the bushings a few weeks before the error. I guess I'd driven around 700km/440miles after the work was done when the error occurred.
Is it possible that a height calibration can cure the problem? Could it have been "thrown off" when the relay went bad. As I mentioned in my first post I had an error that said short circuit in the rear left damper. This is gone after I replaced the relay
Also, it seems like it tries to self level, sort of. When I park on uneven surface it sometimes will drop on one side and then stay that way for a while. Then it will rise up way too hight again.
I should mention that the light and message in the display in the dashboard goes away everytime I stop the care and will come back again after I've driven about a mile
So, what do you guys think, can a height calibration cure the problem, and more importantly, can I do anything wrong if I try to calibrate while I have a C2302 error?
The brackets holding the sensors in place are prone to corrosion, this happened to mine - caused my O/S rear corner to sag. Worth checking your brackets, cheap & easy fix.
I would check/fix this if needed first. If this is the problem you'll need to recalibrate afterwards.
I haven't calibrated yet, I just ran the pre-geometry program which left it with the left front wheel a few millimeters lower than the rest. Maybe I'll have a go at calibrating later.
It would definitely be nice with separate error codes for each sensor. I can't remember if I had any other error codes.
silversurfer1221
27
09-27-2022 02:06 PM
pgvinter
10-08-2015 06:08 PM
04Xjrsteve
11-06-2013 10:53 AM
Purpl E Syrup
10-10-2013 11:43 PM
MANIACK
05-30-2012 09:06 AM
