For anyone thinking about changing their transmission fluid and filter.....
Old Dec 6, 2011 | 03:31 PM
mattrains's Avatar
Default For anyone thinking about changing their transmission fluid and filter.....
I found this excellent how to video that someone made using their 2003 XK8 which has the same transmission that our XJ's have.
Jaguar XK8 Transmission Fluid/Pan Change - YouTube
Take Care,
Mathew
Old Dec 6, 2011 | 03:50 PM
Matt,
That video was made by Reverend Sam a member who usually hangs out in the XK8 section, he has made several more useful videos (and posts here) that you can find on his youtube channel. sam1174's Channel - YouTube
Old Dec 8, 2011 | 12:55 AM
meirion1's Avatar
Default u tube
Thanks for pointing out the video.It was very interesting and informative.
My jag has done 50,000 and I will need to change the ATF fluid at about 60,000
Old Dec 8, 2011 | 12:56 AM
meirion1's Avatar
P.S.
Is an american quart two pints?
Old Dec 8, 2011 | 05:52 AM
It is but it is two US pints which are 16 fluid ounces.
Old Jun 24, 2013 | 01:30 PM
slmskrs's Avatar
From: San Francisco Bay Area (south bay), California USA
Default Transmission fluid scare tactics, or legitimate claim?
Take Care,
Mathew
Reverend Sam used Mercon SP rather than the Jag or ZF / LifeGuard stuff and he says it works great (interested to see if there's been any change or not--probably not). However CTSC says there is no substitute for LifeGuard and if you use something else, know they have great rebuild services, etc (cuz you're going to screw up your transmission). So I sent them an email saying a friend has a Lincoln Navigator which uses the same tranny and Ford recommends Mercon SP. I asked what the difference is such that a recommended fluid on one ZF 6HP26 will damage another. Here's what I got:
"The transmission fluid characteristics is calibrated into the transmission software. Same transmission, different oil à different software calibration."
There is a HUGE weight and load difference between the Navigator and the Jag (I have an older Expedition and pull a 3500# boat, so I'm close to 8000# gross weight), so two completely different requirements.
Does this have merit or not (LifeGuard or Jag stuff is $18-30/liter, while the Meron SP is $6-7)? I always use synthetic oil and change it every 5000 miles. If something is better and will make it last longer, or if there is a legitimate reason (other that marketing, profit, or scare tactics), I'll use it even if it is more expensive. But I'm not convinced yet. On the other hand, I only want to have to deal with this once every 60k, and not end up with a big repair/replacement bill.
Thoughts?
Old Jun 24, 2013 | 01:34 PM
slmskrs's Avatar
Default Ignoring the warm tranny fluid refill process?
One additional question:
Rather than doing the whole running the engine to get the tranny fluid to the correct temp thing, someone responding to Reverend Sam's video on youtube said he just drained it cold, and then put exactly the same amount back into the tranny. I guess assuming it is currently at the correct level when it's drained, that would work, but if not, you could still end up low. But could this be a legitimate fluid partial change method between replacing the pan?
Old Jun 24, 2013 | 05:04 PM
Fraser Mitchell's Avatar
Just draining leaves a lot of old fluid in the torque converter and fluid cooler and lines. A full flush clears out virtually all the old fluid, but is expensive in new fluid as the new is used to flush out the old. The fluid is not cheap, either !
Old Jun 25, 2013 | 12:21 AM
slmskrs's Avatar
When changing the pan/filter, I assume we are not flushing out all the fluid, but just replacing part, and then topping off what was drained out of the pan, etc. Of course, ideally, replacing all in the torque converter wold be best, but since it is "sealed for life" transmission, I'm thinking a partial change every 60k would be sufficient.
If that's not the case, anyone have instructions for flushing the transmission?
Old Jun 25, 2013 | 04:17 AM
steveinfrance's Avatar
This has been debated frequently and most of us just drain + refill using the hot fill method.
Do be sure to check you can remove the filler plug before draining or life can suddenly become sad.
Old Jun 25, 2013 | 05:55 PM
meirion1's Avatar
As Steve says most people fit new pan and filter after draining and refill with 6 litres fluid (cold) , then top up when fluid is about 45 deg C.
Have a look at your ZF supplier here: The CTSC - ZF Parts
for info,supplies and ZF refill method.
Old Jun 26, 2013 | 08:12 AM
ryejag's Avatar
My manual suggests tranny fluid change at 100K miles. Is the latest thinking of 60K miles? I have a 2004 XJR with 73K on it. Not to get off target, but I have the same question for the supercharger oil. Many threads on earlier oil change.
thanks
RyeJa
Old Jun 26, 2013 | 05:15 PM
meirion1's Avatar
I think you will find the consensus is 60 K miles, in fact ZF have said or after 8 years!
Mine is on about 60k now but the fluid has probably been in there for 10 years.
I am just preparing (and getting myself psyched up) to change pan, filter and fluid.
I don't want to break anything, she has been virtually faultless for 5 years!
allenman85
May 10, 2021 03:11 PM
Rupesh
Mar 25, 2016 03:33 PM
Steve Langridge
Sep 3, 2015 07:35 PM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
dpappyp
Aug 27, 2015 06:31 AM
