Attempting a Picnic Tray latch repair
Old Dec 5, 2012 | 02:15 AM
H20boy's Avatar
Default Attempting a Picnic Tray latch repair
Mine just popped off while driving the other day, screw still remained in the seatback, but the rest had fallen to the floor. Its lost some of the plastic around where the screw is supposed to be, but i'm pondering a fix, considering a new latch is in the $80 range from our sponsor, Gaudin Jaguar.
I've got some $15 repair magic goo on order, and will document the attempted fix with instructions and pics, if you think its worth doing. I haven't been around this area long enough to know if the latches fall apart that often...I did find the thread from a JF member who's latches 'exploded' more than once, however.
I wasn't going to try this, but after I figured out how to disassemble the latch so I can have front and rear access to the broken area, I decided to attempt it.
Old Dec 5, 2012 | 04:02 AM
34by151's Avatar
Try superglue and baking soda will plastic weld any plastic
Sprinkle on baking soda after supeglue for an instant set
You can then sand any excess or even attack it with a dremel
Recently repaired a 25mm hole on my mirrors this way.
34by151
Old Dec 6, 2012 | 12:02 AM
H20boy's Avatar
Good top, I'll keep it in mind! I'll start my repair in a couple days time.
Old Nov 10, 2015 | 09:49 AM
Jag52's Avatar
Default Picnic table latch fail
Hi guys, I am on my 4th set of latches. On two occasions the latch failed as they were delivering the car after the latch repair. The failure occures where the latch pin retaining points are located. There is just not enough material in the assembly to insure they are robust enough. I am on the way back to the dealer this thursday to have the both (failed again) latches replaced once more. Oh, did i mention that I don't use them and no one has been in the back seat or even touched them? Jaguar needs to redesign this flimsy piece. Fortunately I am under warranty but it is still frustrating because the repairs are just remove and replace... they will fail again. As soon as these new ones fail I will call Jag NA and explain my patience has worn thin. I can, as you suggest beef up the week area but Jag will not let me do that while under warranty, however I will be interested in how you do this fix, Thanks
2013 XJL 5.0
Tennessee
Old May 21, 2019 | 02:52 PM
altonleehester's Avatar
I know it's been a few years, but, how did you get the assembly apart? I repaired mine and can't get the screw back in. Thanks, in advance!
Old May 18, 2020 | 04:29 PM
dakarf's Avatar
Default Latch
Mine is broken too and im waitimg for the part from ebay. Has anyone successfully fuxed theirs and if so, how?
Old Jan 5, 2024 | 09:00 PM
Kbschicago's Avatar
Default Tray Table Latch
My latch broke. A small plastic piece fell out and it looked like it was broken. I spoke to the service department at the dealership and was told they cant just replace the latch but would have to replace the entire tray table assembiy at a cost of $900+ USD. I see the part online for about $20 USD. It looks fairly easy to replace but don't know if I should attempt it. Am I missing something? Why does the dealer say the latch alone cannot be replaced?
2013 XJL 5.0
Tennessee
Old Feb 9, 2024 | 03:28 PM
Kbschicago's Avatar
How did it work out for you? I am about to order one from ebay,
dude1579
Aug 12, 2019 06:29 AM
Jandreu
Sep 20, 2015 08:20 AM
Vector
US Lower Atlantic
Sep 13, 2015 03:01 PM
findre
Sep 10, 2015 05:46 PM
Jay48
Sep 7, 2015 09:30 PM
