Audio problem
Old May 15, 2017 | 12:18 PM
Christine25's Avatar
Default Audio problem
Hi this is my second jaguar its a XJ6 2004 and I love it but I am frustrated by a recurring fault ,the radio and CD player keeps going on and off my garage has been visited with this problem many times but it's still happening to a lesser degree though anyone any ideas please .
Old May 15, 2017 | 01:23 PM
Welcome to the forum Christine25,
I've copied this question from your Intro to X350 forum. Members here with the same model will be able to help.
Old May 22, 2017 | 08:49 AM
RDMinor's Avatar
When you say "on and off" do you mean it shuts off completely or that the radio switches from FM to AM.
Years ago when I still had my dealership a couple of miles from the space center in Florida we had a series of problems (we weren't alone as evidently this was also a minor national problem) with car radios mysteriously losing their minds and going a tad whacko. It was several months before someone was able to point to a source. It seemed that it would happen most often on a certain stretch of highway that passed the Canaveral Air Force base and the likely culprit was a spurious radio or radar frequency that would confuse the internal tuning circuits in the factory radios. Once Chrysler added a bit more shielding to those circuits the problem went away.
Even now my '99 XK8 will every once in awhile switch from FM to AM when passing under a major high tension transmission line. I would think if it starts happening a lot that the electronic 'noise' suppression circuits were failing.
Only an semi-educated guess mind you but probably pretty close.
JimC64
Sep 22, 2025 02:52 PM
Jeff DeVere
Oct 13, 2016 07:00 AM
Jim D
Oct 8, 2016 11:31 AM
XJ40 ( XJ81 )
Oct 27, 2006 01:02 AM
