Best Brand for Water Pump
High Tack does also come in liquid, and is appropriate for some applications, (low heat and petroleum based fluids) but I am speaking to the aerosol for this application. (high heat and antifreeze) Fitting dry or without elastomers can allow seepage or leakage. Some gaskets are pre-treated and some are not. The one shipped with my Airtex pump was not. The reason the OE gasket doesn't call for sealant in the service manual is because it is a rubberized (elastomer) metal gasket.
Don B (10-27-2017)
Received 12,737 Likes
Out of curiosity, did you use the Workshop Manual torque spec, some other spec, or the feel method?
Cheers,
Don
The pump is not leaking at the engine/pump gasket, its leaking at the gasket that makes up the two halves of the pump body itself. I believe the AC Delco 252-800 is a single piece body pump that eliminates this sandwich gasket. I have one on order. Will report back when I get it.
I've never ever used a torque spec for a compressible gasket like paper, cork or rubber.
Don B (05-26-2018)
#28
Just for the benefit of others who may refer to this thread in the future, the Workshop Manual torque spec table states that on the 3.5L / 4.2L engines the water pump retaining bolts should be torqued to 12 Nm / 9 ft. lbs. However, abonano recently pointed out to me that in the actual water pump replacement section, the manual gives the torque procedure as 8 Nm+90 degrees. Not something easy to guess by feel.
The spec for the water pump pulley screws is 10 Nm + 45 degrees.
Cheers,
Don
XJRay (07-15-2020)
I remember now that the two halves are held together by screws that are separate from the mounting screws. I recently replaced the original pump on an S-Type R and it was a two-part pump - I know this because I inadvertently removed the screws that hold the halves together. I wonder if the screws on your pump were not torqued properly at the factory?
The ACDelco 252-800 I just switched to has a better design in my opinion. Its single piece. And the main inlet/outlet hole seals against the engine with a large O-ring as opposed to a paper gasket like the Airtex pump. The smaller two holes on either side are sealed with an aluminium gasket with preformed rubber sealing surface.
But proof is in the miles. So lets see how long this one lasts this time.
#30
Yes this is very much a possibility. The paper gasket is also a weak point. Its like they used recycled toilet paper or something. It completely disintegrated in just 2000 miles.
#32
If you have time on your hands, I highly recommend ordering a set of new bolts for the job. The last time I did the job the allen heads were almost destroyed from corrosion.
#34
Thought I'd add my experience: Airtex failed on me after 14 months. The impeller completely fell apart.
It happened at the worse time and I was very annoyed. I decided to fork the extra money for an OEM water pump (which had a white impeller, unlike the Airtex) and never look back. It still operates fine after 5 years and 40k miles. I should probably replace it soon, but the point is that the OEM pump is a solid unit. It's worth the extra money, don't waste your time on a $35 Airtex like I did. Not worth the risk
My car is a 1998 XJ8 fyi
#35
#36
Over the past few years, I have installed well over a dozen of these Airtex pumps with the supplied paper gaskets (treated with Permatex Spray-A-Gasket) and have had no problems with any of them. Theoretically I like the OE style metal gasket with rubber edges, but I've tried that type gasket with an Airtex pump and it won't work.
I suspect that one potential cause of problems is that the two screws that secure the two halves of the pump may not always be properly torqued. Also, I suspect the screws securing the pump to the engine are often not properly torqued. Many DIY owners do not own a torque wrench that is accurate in this low torque range (torque wrenches are considered unreliable in the lower 20% of their range). Also, I've adopted the practice of cleaning the threaded holes in the engine with a tap before installing a new water pump, and that seems to prevent a false torque reading due to resistance from corrosion and helps ensure the proper torque is achieved.
If I'm not mistaken, the ACDelco pump has a metal impeller, which will probably be fine for years, but the reason Jaguar and many other manufacturers switched to plastic impellers is that OAT coolants do not protect metal impellers from electrolysis and cavitation erosion.
Cheers,
Don
#37
The interesting thing is that our members have proven that the water pump Jaguar currently supplies as a replacement is the Airtex, and the same Airtex pump is available from Rock Auto for around $35.00. Somewhere here in the forums we have pictures of the two pumps side by side. Airtex is a long-time OEM to Ford, Chrysler, GM and others.
Cheers,
Don
Cheers,
Don
Do I hand feed the installation instructions to the mechanic to ensure they install it properly, but risking they don't and having the pump fail... again. Or do I go with the ACDelco pump, which seems to a more foolproof install...? With the Airtex, seems like proper torque (according to this image you had previously shared) and treating the paper gasket with Permatex Spray-A-Gasket are the most essential steps to a proper install.
#38
Plenty of our members have had good results with the ACDelco pump, and I certainly like the OE gasket and O-ring design. However, remember that "paper" gaskets have been successfully used since the turn of the last century (they were actually made of asbestos), and modern versions are made of fibrous materials like matted graphite, so they are impervious to water when properly torqued.
Cheers,
Don
#39
I think the problem with the airtex pump is that the halves are coming from the factory not torqued together properly. I don't think anyone thinks to retorque the bolts on a new pump but I think this is an important step if you're installing an airtex pump.
Having said that I think the ACDelco design is superior and I would only ever recommend that one.
Don B (06-20-2020)
#40
I have read of a OAT coolant for use in diesel engines that is supposed to be superior to a standard, regular duty, automotive grade OAT coolant like DexCool. I really do not want to change from the OAT.
