Bypass Air suspension warning system.
Old Feb 1, 2019 | 06:44 PM
Bigvettefreak's Avatar
Default Bypass Air suspension warning system.
I am considering having an after market coil over system installed to replace the air ride on my 2006 XJ8L Jaguar. .. How do i avoid getting an error message on the dash warning system? How can the system be bypassed, so that it thinks everything is working properly?
Old Feb 1, 2019 | 11:24 PM
WLinSTL's Avatar
I have an Arnot coilover conversion on my 07 XJR. It came with a bypass 'module' that you install in the control box behind the back seat. Once installed, you will not get any further air suspension or ecats error messages or codes.
Old Feb 2, 2019 | 08:54 PM
Do you know if they sell that module?
Old Feb 2, 2019 | 10:51 PM
WLinSTL's Avatar
The one I got was included with the shocks. I don't know if they sell it as a separate item.
Old Mar 21, 2020 | 04:58 PM
negoshe8n's Avatar
I got the bypass module but with no directions. Can you help with where i am suppose to tap into the air ride
module at?
Old Mar 22, 2020 | 10:12 AM
Wooford XJR's Avatar
The module is located behind the rear seat. I unplugged mine and did a hard rest when I replaced my struts. Lights are gone.
Wooford Jag.
Old Mar 22, 2020 | 05:32 PM
abonano's Avatar
Wooford Jag.
+1
Previous owner did the same.
I was behind the back seat to feed my back up camera wire to the trunk. All the plugs are disconnected from the module.
No warnings whatsoever since I owned the car.
Old Mar 22, 2020 | 07:15 PM
negoshe8n's Avatar
I tried that. I have a 2007. It didn't work. So I got the bypass box but came with no instructions.
Old Mar 22, 2020 | 11:20 PM
Terrific's Avatar
I removed the air ride relay. RH engine compartment box. And a 10 amp fuse, can't remember where. Got my instructions from an earlier post, can;t remember it either. All good Sorry, it sucks to get old.
Old Mar 23, 2020 | 08:22 PM
negoshe8n's Avatar
That worked on a 2007+?
Old Mar 23, 2020 | 11:40 PM
Terrific's Avatar
Actually mine is a 2005, can;t answer for 2007.
Old Jul 7, 2022 | 03:03 AM
Robert 11's Avatar
Default Ebm
Hee goodmorning did you get rid off the air suspension warming without the ebm module 🙂
Old Jul 7, 2022 | 03:52 PM
John in Tennessee's Avatar
Go read this thread. Member gives suggestion on how to use some resistors to fool the ECU. This is before Arnott came up with their module. I think I read somewhere that is is a 5 ohm resistor needed at each wheel sensor.
https://www.jaguarforums.com/forum/x...ersion-110745/
John
Old Jul 8, 2022 | 01:10 AM
Robert 11's Avatar
John
thanks John🙂!
GrewUpJaguar
Mar 20, 2020 04:09 PM
jplportugal
Jul 4, 2016 04:09 PM
Donzi
Sep 7, 2015 12:06 PM
tkeeling
Aug 8, 2014 11:11 AM
amcdonal86
Mar 3, 2012 11:49 AM
