CD Changer
Old Jan 1, 2012 | 10:07 PM
MikalMuh's Avatar
Default CD Changer
To my surprise neither the cd changer in the trunk nor the cd player in the dash will read mp3's. Has anyone purchased an updated cd changer for the trunk that will play mp3's?
Old Jul 29, 2012 | 09:01 PM
irfan's Avatar
Hi,
I just bought xj6 96. In the casset player obtion is cd button. But no cd changer in trunk. Please tell me .. Where i can buy cd changer and where i will connect ? Plase reply.
Irfanjavaid@gmail.com
Old Jul 30, 2012 | 07:20 AM
esloser's Avatar
I'm kind of interested in this answer as well. My 2004 XJ8 didn't come with the CD Changer in the trunk but the button exists on the head unit. Is this a simple thing to install? ie. buy changed, mount in shelf in trunk, and plug into already existing run cable? Or, will I have to run the cable to the head unit from the trunk, hook up to a power source, etc? Thanks, Eric
Old Jul 30, 2012 | 09:19 AM
edobernig's Avatar
Default Burning the CD's
How are you burning the CD? Using itunes I have simply created a play list and used the CD burner feature without any problems.
The wiring harness may be in the trunk under the Nav DVD, However it uses an unusual fiber optic cable as one of the connections. You would have to use the correct changer. The correct Apline changers have been on ebay.
Old Apr 9, 2013 | 12:12 PM
Xeno's Avatar
The Alpine DHA-S690 CD changer plays MP3 tracks. I don't know whether it will work in a Jaguar. It costs $500-700.
Old Apr 10, 2013 | 10:11 AM
gmcgann's Avatar
When you say "work in a Jaguar," if you mean you can plug it into the existing wiring and have it integrate with the rest of the electronics, the answer is no. You need the correct cd changer for the X350, then it should be plug and play. You may or may not have to have the changer enabled by the dealer or someone with IDS/SDD. As far as I know, none of the X350/X358 cd players will read mp3's. If you want that capability you need an ACM.
captbob73
Oct 24, 2015 05:49 PM
mrsteady
Sep 20, 2015 03:38 PM
texaspete
Sep 10, 2015 08:34 AM
al_roethlisberger
Sep 9, 2015 09:14 PM
