Compressor Post Mortem
Old Dec 28, 2011 | 07:05 PM
MK 82's Avatar
Banned
Default Compressor Post Mortem
I did a post mortem on the compressor I just removed. It appears to be a pretty well made unit. It's achilles heel is that the cylinder the piston rides up and down in wears out--not the seal. The is a noticeable groove in it. I was also surprised to find a dessicant cannister in it with a lot of water and a very rusty spring. Would not be hard to rebuild if you had the parts. The motor including brushes is pristine. I will try to post some pics in the next couple of days.
Old Dec 29, 2011 | 03:12 PM
SuperTrav's Avatar
That's great information, Eddie. Thank you. Do you believe we could replace the cylinder, or make a sleeve for it, then clean up and refresh the dessicant canister? I would love to know your $.02.
Old Dec 29, 2011 | 03:42 PM
Fraser Mitchell's Avatar
It may be well made but I would prefer if it was made just a little bit better, as they don't seem to last very long.
Clearly the area for improvement is the compressor cylinder, and possibly the water trap purging process.
Old Dec 29, 2011 | 04:44 PM
mark campbell's Avatar
opps just put a complete unit on sale on e-bay---loading parts froma a scrap car --went to look here--well its still cheep
Old Dec 29, 2011 | 05:00 PM
MK 82's Avatar
Banned
As I said, it is definitely rebuildable. Too bad there is not a kit. The cylinder is definitely the weak spot.
Old Dec 30, 2011 | 04:39 AM
reyesl's Avatar
Jaguar has a Remanufatured Unit, part# C2C27702E listed in the XJ Parts List. So there has to be a rebuild kit out there, maybe direct from Wabco?
I ordered several used units from EBay and will attempt to swap parts to rebuild one of them as a standby.
Old Dec 30, 2011 | 04:56 AM
I had one of the remanufactured units fitted last year, on a service exchange basis, so clearly there is a process for rebuilding these units.
Old Dec 30, 2011 | 10:47 AM
MK 82's Avatar
Banned
Trouble is that they will all have worn cylinders and rusty parts and worn dessicant.
If there is a rebuild kit out there, it is a well kept secret.
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
tonyforman
Sep 10, 2015 07:23 PM
1100me
Sep 7, 2015 06:26 AM
Corycarlo
Sep 5, 2015 11:41 AM
d a
Sep 3, 2015 02:34 AM
