Computer Problems with XJ8
Old Jan 14, 2014 | 08:49 AM
pearsonjayw's Avatar
Default Computer Problems with XJ8
I love my 04 XJ8 but I ma at my wits end. A few months ago my battery went out and I replaced it. Since then every 2 or 3 weeks my dashboard lights up and it throws Gearbox Fault, ABS Fault, Steering Fault, Air Suspension Fault, and the dash instruments stop working. I take it to my mechanic and he clears the codes, and purges all faults and for a few weeks it is fine. I am hoping this fine group can help me. I do not mind investing in replacing the computer if that would solve the issue, but my confidence it will is very low.
Old Jan 14, 2014 | 08:58 AM
Welcome to the forum,
I've moved your thread to the tech section where you will get a better response.
Don't forget your intro in the new members section.
Old Jan 14, 2014 | 09:16 AM
SaturnV's Avatar
Might as well rule out the simple stuff first.
Have the battery tested, brand new units off the shelf have been know to be defective, also confirm the installer thoroughly cleaned your cable ends. You can also try a hard reset, procedure is outlined on the interwebs.
Check your grounds (earth points). Start in the trunk near the battery. There was one in particular on our XJ that I found to be loose when I put the new battery in. Look online, there is a diagram of the rest of the grounding points so you can track each one down and check it....there are quite a few on these cars.
Next, check your voltage output from the charging system. Perhaps the car is draining the new battery down. The XJ8 just doesn't do well with anything but a healthy batt and charge system.
Last, has the engine bay gotten wet around the time of the trouble?
Old Jan 14, 2014 | 12:41 PM
ed1979's Avatar
I had the same issue and I eventually got to the bottom of it.
In my case it related to water from power washing, or heavy rain, etc. damaging the ECM over a long time period.
Check that the cars Pollen filter drainage plug is not blocked. If it is, and your car has the same design as an X350, it could have blocked up with water and overflowed into the ECM unit.
Corrosion can build up on the circuit board over time and when water gets in it becomes conductive.
No diagnostic software in the world will tell you that problem.
Old Jan 15, 2014 | 08:10 AM
Default Thanks for the responses
Thank you for pointing me in some good directions. I guess I know what I am doing this weekend.
FrickenJag
Jun 16, 2025 02:15 PM
dsnyder586
Dec 29, 2024 07:39 PM
SteveSheldon
UK & Eire
505
Jul 14, 2016 04:48 AM
obwoodie
Sep 3, 2015 07:45 PM
laserguy
Sep 3, 2015 02:02 PM
