Condenser oring replacement
Old Mar 4, 2019 | 07:32 AM
mhamilton's Avatar
Angry Condenser oring replacement
Does anyone know the correct size for the 2 o-rings used on the lines to the a/c condenser? Or the Jag part number? Jaguar parts catalog does not show a breakdown with o-rings, just the line sets. Both rings are the same size.
Completely frustrated that I did not have a correct size replacement o-ring while in the middle of my condenser replacement, even though I have a box set of ac o-rings and I bought a bag of o-rings supposedly for this vehicle (none of those looked even remotely close to fitting anyplace on the Jag). Had to put back the originals. Expecting those to leak.
Thanks,
-Michael
Old Mar 6, 2019 | 12:01 PM
mhamilton's Avatar
To answer my own question, the original Jag part number is C2N1185 for the condenser o-rings on the x350 XJ. However, they are approx $7 each and have to be ordered. I found part number XR83775 is the condenser o-ring for the S-Type, XF, XK, and the X Type for models from the early 2000s through 2010s. At only $1-change I've ordered 2 of these. From looking at the condensers themselves, it appears they will be the same. I will post back to confirm.
Old Mar 18, 2019 | 07:00 AM
mhamilton's Avatar
To follow up, C2N1185 is the correct o-ring for the condenser lines. The later part (XR83775) is too small. The dimensions of the correct o-rings are 10 mm ID, 2 mm CS. They are black colored o-rings just like the factory ones on the car, which surprised me. Usually HNBR are green, but that's just dye added for identification purposes. I would not use a plain rubber o-ring on the a/c system.
Old Mar 18, 2019 | 07:56 AM
Wingrider's Avatar
Try a local bearing shop if you have one..
Otherwise since you now have the sizes.
The internet should provide a source.
Ebay with Pay Pal seems to work for me,finding stuff.
Old Mar 18, 2019 | 11:11 AM
mhamilton's Avatar
Now that I have measurements they're a dime a dozen. Problem was I didn't want to take the system apart and leave it open to atmosphere while I dissected the original o-rings. Hopefully this is of some help to someone else in the future.
Old Nov 10, 2021 | 07:44 PM
meirion1's Avatar
Yes me!
Thank you
RaceDiagnostics
Aug 27, 2021 06:57 AM
Alster370
Oct 3, 2018 06:12 AM
BlackKat
Jun 10, 2018 01:51 PM
nasomi
Oct 17, 2016 09:07 PM
mhamilton
Dec 2, 2013 09:20 AM
