Cooling fan
Old Jul 30, 2015 | 06:40 PM
clifton94's Avatar
Default Cooling fan
Hi does anyone know what temp the cooling fan should start at mine starts at 92 degrees slowly at first then if the temp rises above this it turns faster is this normal car has had new thermostat,car does not overheat or lose water . Checked the temp from the obd and also with a laser temp sensor aimed at the temp switch both the same is this normal and me being paranoid or have I got a problem with the car
Old Jul 30, 2015 | 07:07 PM
Partick the Cat's Avatar
Neither the technical description document nor the workshop manual quote a figure for the temperature at which fan starts to operate. What they say is:-
"The speed is determined by the Engine Coolant Temperature (ECT), the air conditioning pressure, and the transmission oil temperature."
Old Jul 31, 2015 | 03:22 AM
clifton94's Avatar
Thank you for that information Patrick the cat
mikiep
Dec 20, 2019 07:37 PM
Seth
Nov 1, 2015 12:17 PM
emilime75
XJ XJ12 ( X305 )
Oct 19, 2015 09:55 PM
LnrB
Oct 13, 2015 12:45 AM
workworkwork
Oct 1, 2015 01:44 AM
