Cooling System Fault--Advice Requested
Old Nov 20, 2024 | 07:02 AM
Petz's Avatar
Waterpump is in the front . Unlikely to send coolsnt to the back of engine. Should be the valley hose behind thermostat , under throttlebody under manifold.
there are also the knock sensors in the valley. They usually onLy fail trough corrosion after being immersed with coolant
manifold gsskets is not such s bad idea
Water pump could be done at the same time . Thermostat housing can get briddle over time.
i will ad some picture from my spare
Old Nov 29, 2024 | 01:28 PM
312XJ's Avatar
Hello everyone, I got the car back last week and everything seems to be back to normal. Thanks to all for the helpful advice.
Old Nov 30, 2024 | 10:58 AM
Petz's Avatar
Now what has ben done to it? What was it?
Old Nov 30, 2024 | 12:04 PM
312XJ's Avatar
Replaced the thermostat housing, thermostat, expansion tank, and serpentine belt, flushed and refilled with OAT coolant.
Old Dec 1, 2024 | 03:22 AM
Petz's Avatar
Check a couple of times on the level for the next couple of days. Prone to have air locked inside.
gkubrak
Mar 30, 2026 12:50 PM
bocatrip
Jun 6, 2022 11:37 AM
ChrisTX
May 1, 2020 05:17 AM
Thermo
Jun 30, 2018 10:29 PM
jcreaden
Jul 23, 2017 02:39 PM
