Correct temp for A/C
Old Oct 4, 2011 | 07:04 PM
jahummer's Avatar
Default Correct temp for A/C
Seems to me over the past year it is taking longer for the air coming from the vents to cool. Dealer said everything is fine and the temp should be 52 degrees F.
Anyone know the correct Jaguar factory specification at the vent with recirculate on & off?
Old Oct 4, 2011 | 10:35 PM
amcdonal86's Avatar
52 degrees sounds about right. What temperature is the air coming out of there?
Old Oct 5, 2011 | 07:17 AM
limelight's Avatar
Temp should be in the mid 40's minimum.
Old Oct 5, 2011 | 08:02 AM
kthrash's Avatar
Is the temp the same out of all the vents? I have an issue where my driver side is warmer than my passenger side.. I think the blend flap on the driver side is not closing all the way in the AC position.
Old Oct 5, 2011 | 09:35 AM
amcdonal86's Avatar
Doing a quick Google search seems to show a consensus that if the vent temperatures are somewhere in the low 50s at idle, you are in good shape.
Then again, it probably depends on the car. My Jaguar never had particularly cold A/C, but my Ford's is ice cold!
Old Oct 5, 2011 | 09:49 AM
jahummer's Avatar
Hoping someone knew if Jaguar had a factory spec. Car is still at Jaguar, when I get it back, I'll check the temps but I do believe the outside vent temps were different from the middle ones.
Old Oct 6, 2011 | 08:07 PM
jahummer's Avatar
I checked one of my other cars and the recirc temp was 44.1 and with recirc off it was 46.3 so Jaguar is looking into it...
Old Oct 7, 2011 | 07:58 AM
limelight's Avatar
That sounds more like it.
Jandreu
Jun 30, 2022 03:10 PM
Mac Allan
Oct 27, 2015 04:49 AM
chatmanx
Sep 11, 2015 07:17 PM
tberg
Sep 7, 2015 07:32 AM
Bcrary3
Sep 3, 2015 03:48 PM
