Cruise Control not Available - No Visible Corosion
Old 02-25-2023, 02:12 PM
PowdyrdWyg's Avatar
Default Cruise Control not Available - No Visible Corosion
Upon starting my 2004 XJR, I am greater with am amber light and the message, “cruise control not available.” Having read about water intrusion in the adaptive cruise control module, I removed the ACC unit from the car. By removing the module from the mounting bracket, I was able to remove it through the opening next to the fog light.
It appears sealed; there is no evidence of water intrusion or corrosion. There was also no evidence of corrosion in the cavity where the module is located. Absent evidence of water intrusion, I am hesitant to open the module as that will require destructive measures.
Any idea what the problem is? My iCarly and OBDWiz do not show any fault codes. Can one download SDD? Thanks.
Old 02-25-2023, 03:23 PM
ChrisMills's Avatar
Corrosion or not, re-plugging connectors might help. Makes a new swipe on the contacts.
Old 02-25-2023, 06:49 PM
PowdyrdWyg's Avatar
Thanks, Chris. I did that, and the warning came back along with “no forward alert.” I’ve ordered IDS. Perhaps that will shed light on the issue.
Otherwise, I was able to put the bracket on the module outside of the car, stick it in upside down, plug it in, and rotate it into place. Removing the fog light is easy and helps a great deal.
Old 02-25-2023, 07:22 PM
ChrisMills's Avatar
I don't have ACC. But I've read a lot about it in this forum (hint hint).
There might be other connectors. 90% or more of computer problems are connectors.
Old 02-26-2023, 07:14 AM
Sochi2014's Avatar
For sure you need to scan it by IDS/SDD. It can be box position angle out of range in the bracket or can link fail to ECM.. Thats's what i have seen so far in my car
Old 02-26-2023, 12:36 PM
xalty's Avatar
Received 1,053 Likes on 846 Posts
good luck
Old 02-28-2023, 09:37 AM
wfooshee's Avatar
Any other weirdnesses at any time? I mean any? I had occasional "Cruise not available" and "unable to set parkbrake" until I replaced my battery. The car is sensitive to undervolts of literally tenths of a volt. No messages since the new battery.
Old 03-04-2023, 07:05 AM
Wingrider's Avatar
+ 1 on the battery!!!
Symptoms;
The car starts up, idle levels down, runs, & drives fine.
Shutting the motor off, on the restart, the warnings are gone.
A voltage drop test, should answer your batterys condition question
Red Baron
09-11-2022 12:32 PM
Lukeh08
XE ( X760 )
07-06-2022 09:40 AM
ryejag
02-02-2020 04:05 PM
XJRTrooper
24
01-11-2015 06:37 PM
desertkitty
03-28-2012 09:22 AM
Quick Reply: Cruise Control not Available - No Visible Corosion
