Difference between rear lower A arms
Old May 20, 2024 | 01:16 PM
Sprite's Avatar
Default Difference between rear lower A arms
Is there a difference between the rear lower A arms on an S model then on an XJ8? Found some for an S model at a great price and wonder if they would work on my XJ8!
Old May 23, 2024 | 06:01 PM
Pete M's Avatar
Have a look on JLR Classic Parts website (https://parts.jaguarlandroverclassic...03-2009-parts/) for the part number that matches up with your VIN. This part did change at some point. Then look up the S (I assume you mean S-Type) section on the website and do the same. If the numbers match then that is your answer.
Pete M
Old May 26, 2024 | 03:38 PM
Petz's Avatar
G41511 the change happened on rear lower
Old May 26, 2024 | 04:14 PM
Petz's Avatar
Lemförder 39713-01 lower rear left
Lemförder 39714-01 lower rear right from G41512 onwards
Lemförder 39839-01 lower rear left
Lemförder 39840-01 lower rear right till G41512
87LC2
30
Feb 22, 2023 08:58 AM
Kdog
Jul 1, 2017 10:57 AM
Panelhead
May 12, 2015 02:32 PM
afonda
Apr 13, 2013 07:52 AM
SirJag
Jul 15, 2011 12:34 AM
