Disk Installed is not a Map CD ???
Old Dec 20, 2013 | 02:31 PM
BoxxMann's Avatar
Angry Disk Installed is not a Map CD ???
Hi all,
I've done a google search and also tried to find information here for a solution. Unfortunately, the best suggestion I can find for the error message:
is to replace the GPS disk in the boot. While not having a GPS is really not an issue, I was hoping to know a better solution to getting the reader to read the disk I have (actually have tried two) without buying a replacement.
Does anyone know a workaround or is the reader kaput?
Thank you!
Boxx
Old Dec 20, 2013 | 05:06 PM
gmcgann's Avatar
I've gotten that message a few times. Usually it works ok the next time I start the car. I never put the OEM disc in the drive. I make a copy and use that. If it gives me that message more than once or twice I just burn a new disc.
Old Dec 21, 2013 | 03:57 AM
PigletJohn's Avatar
you might consider using a lens-cleaning CD.
Old Dec 21, 2013 | 11:15 PM
Growl-R's Avatar
I recently purchased a 2005 Super V8. I was getting the same message on my nav screen. I popped out the DVD map disc and cleaned it. It now works like a champ! My first modification will be to upgrade the map disk to a more current edition.
Cheers!
Jon
Old Dec 22, 2013 | 08:02 PM
BoxxMann's Avatar
I'll try the low cost ideas of cleaning first...have tried two disks with the same error.
Old Dec 23, 2013 | 09:14 PM
BoxxMann's Avatar
Cleaned two identical disks and inop. Looks like time for a new drive
Old Dec 24, 2013 | 03:35 AM
PigletJohn's Avatar
Have you used a lens cleaning disc to clean the drive?
Old Dec 24, 2013 | 09:18 AM
MarcB's Avatar
I had the same problem and then purchased a DVD/CD cleaner disc. I was very skeptical but so far so good. The disc I purchased has 5 little brushes on it, it had instructions to play it and follow the instructions but since our systems do not work like that I just inserted it and let it run for a couple of minutes. It has been two days now and the system has not shown any symptoms, such as slow loading or the not a map DVD message, it has also improved the performance (speed) of the system.
Old Dec 25, 2013 | 12:04 PM
BoxxMann's Avatar
So I've ordered in a CD/DVD cleaning disk gizmo...I'll report my results when the shipment arrives. It was 6 bucks...fingers are crossed this will remedy the situation
Old Dec 30, 2013 | 07:55 PM
BoxxMann's Avatar
I've received the cleaning kit. I followed the instructions and still receive the same error. At this point I'm going to have to assume that the Nav CD reader is kaput
Old Jan 2, 2014 | 12:51 AM
reyesl's Avatar
Nav disk for sale:
2007 JAGUAR XK NAVAGATION DISK
Old Jan 2, 2014 | 03:39 AM
Cambo's Avatar
Originally Posted by reyesl
XK discs don't work with the X350
Old Jan 2, 2014 | 07:07 AM
reyesl's Avatar
The disk indicates for XJ and XK.
Old Jan 2, 2014 | 07:38 AM
Cambo's Avatar
Wrong XJ, that's for an X308 with the Alpine Nav, X350's have the Denso system.
Old Jan 2, 2014 | 06:29 PM
reyesl's Avatar
Thanks for the correction, didn't notice that. I checked both of my disks and they do indicate DENSO...
Shawn Svacha
Feb 6, 2022 04:53 PM
PMKimpton
Aug 3, 2019 08:22 PM
Donzi
Oct 18, 2018 12:26 AM
fingers
General Tech Help
Oct 21, 2015 02:02 AM
pegasus3710
Sep 5, 2015 09:40 AM
