Door problem with 2004 XJ8
Old Mar 26, 2011 | 12:06 PM
swany's Avatar
Default Door problem with 2004 XJ8
All of a sudden the keyless entry (either of them) will not lock or unlock the car doors or trunk (it gives the "beep-beep" error sound). When I open one of the doors, I get a regular intermitent bing, bing, bing, bing as though I've left my keys in the ignition or there's some sort of error. When I use the key in the driver's side door, it does work, but it still gives me a beep-beep sound when locking. The car starts fine and shows no error codes.
Is this likely an issue with the keyless entry, or the ignition key sensor thinking a key's in there?
Old Mar 26, 2011 | 05:02 PM
meirion1's Avatar
Just check that the little "door" on the ignition socket is not stuck open.
Old Mar 27, 2011 | 12:32 PM
swany's Avatar
Yah, I fiddled with it some more once I suspected this to be the problem and it is that key door sticking open. Is there anything I can do to clean it and keep it from sticking? I'd be hesitant to spray WD-40 there.
Old Mar 27, 2011 | 03:09 PM
meirion1's Avatar
I would think that a little spot of WD 40 would be ok
JarodL
Mar 7, 2024 01:39 AM
kelliott
May 31, 2022 05:26 PM
XJsc-guy
Nov 23, 2015 01:56 PM
alpecsa
Sep 7, 2015 11:55 AM
laserguy
Sep 3, 2015 02:02 PM
