Driver Mirror
Old Nov 29, 2014 | 09:59 AM
jspinellijr's Avatar
Default Driver Mirror
I having an odd problem with my driver side mirror, it keep moving around on it's own and dosen't stop. I think it has to do with the keyless entry. Any ideas?
Thanks Joe
Old Nov 29, 2014 | 11:07 AM
Rrd623's Avatar
Default Mirror Gremlin
Based on the info provided, I would begin at the mirror control panel on the drivers door.
If the problem stops when you select the passenger side mirror, then the problem is likely in the control switch itself. (Right, left, up, down buttons stuck down perhaps?)
If the mirror continues to move regardless of the switch position, I would search for a short to earth in the harness leading to the mirror itself.
Another thought; many have had success with disconnecting and reconnecting the battery for strange electrical malfunctions.
Perhaps a little more information would be helpful as well. (Year and model?)
Good luck, hope this helps!
St.Regis
Oct 4, 2024 12:07 PM
kevinl
Oct 31, 2019 06:15 PM
Razor
Aug 28, 2019 08:34 PM
rentzoo
Nov 10, 2015 04:56 PM
avern1
Sep 8, 2015 06:25 PM
