Driver side rear view mirror issue.
Old Apr 6, 2014 | 05:31 AM
Rausch's Avatar
Angry Driver side rear view mirror issue.
On my 2004 xj8 when I remotely unlock the car and start the ignition the drivers side rear view mirror points down and will not return to the normal position when the car is put in drive. The passenger side mirror points down as well when backing but does not point as far down and puts itself in the proper position when the drive gear is engaged. HELP
Old Apr 6, 2014 | 06:11 PM
paydase's Avatar
I fear you may have to live with the demons
I had a similar problem six months ago, then it disappeared miraculously three months ago, then came back two weeks ago just once, then disappeared again.
See my thread:
https://www.jaguarforums.com/forum/x...nt-open-98855/
Good luck!
Old Apr 6, 2014 | 06:55 PM
Lagonia's Avatar
Ah, so, the driver's side mirror going down on reverse is programmable (I know because I have done it myself). In other words, if you have access to the IDS/SDD software (via Jag dealer or indy) you can ask them to set the driver's side mirror NOT to go down when the gear is put in reverse. It is an alternative that may be worth pursuing.
Old Apr 9, 2014 | 07:12 AM
Rausch's Avatar
JarodL
Mar 7, 2024 01:39 AM
SD96XJ6L
Jan 12, 2022 04:30 AM
Raul Lara
Sep 14, 2015 07:31 PM
tberg
Sep 7, 2015 07:32 AM
innzane
Sep 2, 2015 10:08 AM
