Drivers seat
Old Dec 6, 2019 | 03:56 PM
Andiepops's Avatar
Default Drivers seat
Ok as with most i guess my drivers seat when turning off the car drops down and slides right back i guess making getting in and out easier, problem is for me it doesnt, in fact its a bloody nuisance is there a way this can be turned off so the seat just stays where it is
Old Dec 6, 2019 | 10:12 PM
Mark in Maine's Avatar
Yes, just turn the round knob on the left side of the steering column to "column". This deactivates the entry/exit mode.
Old Dec 8, 2019 | 03:21 AM
Andiepops's Avatar
Default Thanks
Wow how easy a solution is that, many many thanks, you may well have saved my back for christmas
Old Dec 9, 2019 | 12:28 AM
toyman1001's Avatar
That solution may leave the steering wheel in a position that is too low for easy access. The other option is to create a easy access position using the seat memory function, say memory 3.
Old Dec 9, 2019 | 06:13 AM
Wingrider's Avatar
After disconnecting the battery, then setting everything the way you want, i just leave the memory button alone.
Like Mark said set the switch on the column, & things will stay where you left them.
The less one uses all the seat motors, the longer they last.
When & if the seat motors no longer work, your in a fix.
Bells & whistles are great when they work properly, not so much when they don't.
Old Dec 9, 2019 | 06:55 AM
redrover41's Avatar
I have setting 1 for my preferred seating height, pedal reach, back and seat tilts, etc. MY wife has 2 set for her preferences. I set 3 when I had knee surgety to go all the way back, lift the seat to a good exit position have left it there for 2 years. When I have those days that I'm feeling my age and creaking, it is a good egress setting. Then I hit 1 and off I go.
Razzor19
Jul 27, 2016 09:19 AM
Linda's Jag
Jan 13, 2011 11:24 PM
Linda's Jag
wolvesfan
Mar 29, 2010 11:30 AM
rgzx11
Jul 29, 2008 03:06 AM
