Egr bolts
Old May 15, 2016 | 03:16 PM
BlackKat's Avatar
Default Egr bolts
Anyone know where I can get replacement egr bolts, or at least size and threads of bolts? Got a new egr valve but have a stripped bolt I'm going to need to replace.
Thanks in advance!
Old May 15, 2016 | 03:33 PM
xdave's Avatar
Being in the US I am assuming a petrol not diesel X350. There are two types of bolt used with the EGR valve - one which goes in through the bottom and clamps the pipe to the valve through a gasket (Item 8, M8 x 20mm JFS108207) and one that screws into the side and looks to be a mounting bolt (Item 7, M6 x 45mm AJ82190). The latter appears to be only part threaded.
Old May 15, 2016 | 09:56 PM
BlackKat's Avatar
Thanks xDave. You the man! Are these the same for the supercharged engine?
Old May 16, 2016 | 04:04 AM
xdave's Avatar
I can't see any different parts listed for the supercharged V8 so they should be the same.
Old May 18, 2016 | 03:04 PM
gm_jim's Avatar
The EGR bolts that run through the valve and attach it to the elbow (supercharged models) are identical to the four bolts that hold the throttle body to the elbow. When I've had the EGR valve, elbow and throttle body apart I've used the two bolts with the best hex heads on them for the EGR due to the accessibility issues with them.
AlexJag
May 17, 2016 01:00 PM
Narda 1
May 16, 2016 06:34 AM
Mr rx-7 tt
May 13, 2016 11:13 PM
maniqz
May 13, 2016 05:30 AM
springer
May 11, 2016 12:38 PM
