Engine Fan Is This Normal?
Old Feb 15, 2015 | 10:13 AM
philj2050's Avatar
Default Engine Fan Is This Normal?
Was Under The Hood On My XJ6 Today Engine Had Been Running For Over 20mins Car Was At Idle Temp And I Noticed The Engine Fan Was Not Working Is This Normal And Does It Only Come On At Certain Times Or Should It Run Soon As The Engine Starts?
I Even Got In The Car And Went For A Drive Came Back And It Was Still Not Running Just Want To Know If This Is Normal
Old Feb 15, 2015 | 11:15 AM
abonano's Avatar
I think you should post this in the X308 forum (moderators - could you please move) to get more in depth responses.
I guess it's dependent on ambient temperature. If super cold - it's a possibility, otherwise - it could be a problem...
Check all associated fuses and relay to your engine fan and ensure your coolant is topped off and you have no leaks..
mbergen
Oct 23, 2019 10:26 PM
cissdm
May 3, 2016 06:02 AM
brgjag
General Tech Help
17
Sep 9, 2015 07:34 AM
tberg
Sep 7, 2015 07:32 AM
bdboyle
Sep 4, 2015 06:16 AM
