Engine Malfunction Light On
Old Jul 14, 2013 | 03:51 PM
banjobill's Avatar
Default Engine Malfunction Light On
Hi All,
just driving along, and the warning light came on the dash, the engine malfunction light?, the car drives normal, no fault messages, yet, but I have no code reader, will try to get to the garage tomorrow, but where should I be looking for problems?
Another query, while looking around under the bonnet, I noticed the radiator top hose was a bit flat? I mean it looked a little squashed, I tried squeezing it to re-shape it, it did a little but I thought the hose was a little soft and to easy to squeeze, is this normal or is it faulty?
regards.
Old Jul 14, 2013 | 05:56 PM
meirion1's Avatar
If you have an i phone you can download an app called Torque and I believe you
can use it to read and clear codes or you can buy an OBD code reader,usually
for less than a dealer will charge for one scan.
Old Jul 15, 2013 | 04:45 AM
banjobill's Avatar
Thanks for that, I might look into that APP, I've looking to buy a code reader but unsure of which model.
regards.
toronadomike
Jan 22, 2026 10:13 PM
D.K
Dec 10, 2023 02:05 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
laserguy
Sep 3, 2015 02:02 PM
TC Johnson
Sep 2, 2015 09:30 AM
