Fault secundairy air pump
Old Dec 31, 2024 | 11:57 AM
Leonmaas's Avatar
Exclamation Fault secundairy air pump
Hi all,
For some time i have problems with the secundairy air pump.
It was full aff water and did not turn.
I replaced the pump, relais end secundairy air valve.
The fault code P 4222 comes back and the pump will not run.
If i test it directly the pump runs.
Reais is also working ifvtested outside the car.
The negative wire has no connection to ground.
If i disconnect the vacuum valve another fault code appears.
To me it seems the relais is not getting a signal so that the pump swiches on.
Can anybody help how to diagnose further?
Thanks in advance
Regards,
Leon
Old Dec 31, 2024 | 09:13 PM
kg74's Avatar
I think you are on the right track. It appears your pump seized, grounded out and drew too much power. So check relevant fuse(s) and relay. After that wiring.
Old Jan 1, 2025 | 10:07 AM
Leonmaas's Avatar
Thanks for answering.
Today i have learned from the workshop manual that there is an in line fuse between the fuse box engine compatement en the relais of the pump.
Do you know where this one is located or do i need to remove the whole bumper agin for acces?
It is a fuse of 40 amps and could be the reason of the problem.
Old Jan 6, 2025 | 03:53 AM
Thomas-S.'s Avatar
Hi,
it would be helpful if you could specify what car you have (engine type, year, etc). Maybe you could add the details to your signature?
Best regards,
Thomas
Old Jan 6, 2025 | 06:22 AM
Leonmaas's Avatar
Originally Posted by Thomas-S.
Hi,
Best regards,
Thomas
Thanks Thomas,
I will update profile when home.
2006 3.0 V6
At this moment when I connect 3 and 5 from relais the pump starts running.
This part is ok.
pin 1 from relais does not get 12v
Fuse 27 is ok
on scheme the relais is controlled by ECU, I don’t know how to test this circuit???
any suggestions?
regards leon
Old Jan 7, 2025 | 02:22 PM
Petz's Avatar
Recently chsnged radiator on v6 from 2004. Wich has the washer bottle in the front right behind bumper.
if you take the lower plastic off you can see all the connectors towards fan auxpump reservoir level
Old Jan 11, 2025 | 12:39 PM
Leonmaas's Avatar
Hi all,
Problem is solved after checking all and even removing ecu the fault was found in the connector from the relais secundary airpump.
The positive wire was burned inside the connector.
I have learned that floating fuse no. 2 does not excist.
In the manual pge 79 car 2006 there is a fuse but it's only on paper.
Thanks for all reply's
Patrick 1989 XJS
Sep 24, 2024 08:00 AM
JansJags
Mar 31, 2021 05:06 PM
stran0020
XJ40 ( XJ81 )
Feb 3, 2021 07:45 PM
VancouverXJ6
Feb 3, 2018 03:13 AM
jagman96
Dec 23, 2010 08:04 AM
