Filling with fuel issues
Old Sep 23, 2022 | 08:03 AM
87LC2's Avatar
Default Filling with fuel issues
Did some searching and did not find much on this issue for the x350 - When filling with fuel the pump cuts off every 2-3 seconds making it take an eternity to put even 10 gallons in the car. Pretty sure its hitting the auto shut-off as if the tank were full but its clearly not. Want to get this rectified before winter, no fun taking 20-25 minutes to fill the car with gas. I assume its related to an evap or vent sensor/solenoid, but hoping someone has dealt with this before and can point me in the right direction. Thanks in advance.
Old Sep 23, 2022 | 10:54 AM
wfooshee's Avatar
Happens to me once in a while, but not all the time, somehow. I've had to adjust the positioning of the filler nozzle as it sits in the neck, just turn it a bit one way or the other, or even back it out an inch or so, still past the little hole it goes through. (If you're not old enough to remember leaded fuel at the pumps, that hole is a leftover from the conversion to lead-free gasoline. Pumps for lead-free had a smaller nozzle than pumps for leaded gas, so the nozzle for leaded gas would not go into the filler neck. Using leaded fuel in a car with catalytic converters destroys the catalyst, so that's how they prevented it at the time.)
Old Sep 23, 2022 | 11:04 AM
87LC2's Avatar
Originally Posted by wfooshee
happens to me once in a while, but not all the time, somehow. I've had to adjust the positioning of the filler nozzle as it sits in the neck, just turn it a bit one way or the other, or even back it out an inch or so, still past the little hole it goes through. (If you're not old enough to remember leaded fuel at the pumps, that hole is a leftover from the conversion to lead-free gasoline. Pumps for lead-free had a smaller nozzle than pumps for leaded gas, so the nozzle for leaded gas would not go into the filler neck. Using leaded fuel in a car with catalytic converters destroys the catalyst, so that's how they prevented it at the time.)
I've had issues on x308s in the past and tried every trick in the book on this one. Pulled the nozzle out a bit, pumped slower, turned the handle, etc. and nothing. I did some more searching and this does not seem like a common issue on the x350, hopefuly someone has ran into this and can offer a solution. I'll try to fill it up again and move the pump around more, but the fact that this isn't a more common trend leads me to believe there's definitely an issue with my particular car.
Old Sep 24, 2022 | 12:36 PM
mhannaoui's Avatar
No solution from me, but this started happening to me every single time over a year ago, at least I don't recall having this issue before. I've tried repositioning the nozzle, but nothing worked so far. It is annoying, but I've come to accept it, and the key for me is not being able to tell when the tank is full, so I now estimate based on price or number of gallons and sometimes I turn the key on and watch the gas needle from the rear as I pump gas.
Old Sep 24, 2022 | 02:10 PM
87LC2's Avatar
Thanks for the reply, at least I'm not the only one. It's not the biggest deal right now, but when winter comes I'm not going to be too happy. Would also like to fill the tank at some point and calculate mileage.
Hopefully somebody has a solution. Has to be a vent issue of some sort.
Old Sep 24, 2022 | 03:33 PM
Wingrider's Avatar
Guessing that you have an issue venting the gas fumes somehow.
No idea where to look
Old Sep 24, 2022 | 06:06 PM
87LC2's Avatar
Yea, that's what I'm thinking. I'll have to go through the manual and figure something out. Was hoping it was one of those common Jag issues but I guess not.
Old Sep 25, 2022 | 01:58 AM
ChrisMills's Avatar
I theorise that you could try inserting the nozzle upside down. To help keep the venturi clear.
Once you have mastered how to put gas in your car, we can move on to, oh I dunno, ZF transmissions...
Old Sep 25, 2022 | 06:12 AM
87LC2's Avatar
Gave it another shot last night and couldn't find a position that would work, even upside down. Did manage to fill the tank, but it took about 20 minutes.
Looked through JTIS and apparently the charcoal canister is on top of the fuel tank, great design. Looks like the tank and subframe would have to be removed to get to it. The purge valve is easier to get to, but not sure if that would cause this issue.
Old Sep 25, 2022 | 08:31 AM
xalty's Avatar
the 06 has a eurotrash leak detection pump vent solenoid combo thing
https://www.autohausaz.com/pn/30173_213_2105_1014__6_5-0261222018?utm_source=google&utm_medium=cpc&utm_ca mpaign=feedmobile_Volvo&gclid=CjwKCAjw-L-ZBhB4EiwA76YzOUAjvjDDE9R_GYQ7SFW98LaUu0iGkkTHYObKD zCQybLgQqXl8WmBahoCNyoQAvD_BwE
Old Sep 25, 2022 | 04:05 PM
87LC2's Avatar
https://www.autohausaz.com/pn/30173_...hoCNyoQAvD_BwE
Do you know where that is located? Seems if it fails it would throw a light or code, I have neither?
cstall
May 17, 2021 03:52 PM
TwiztOG43
Sep 6, 2016 01:50 AM
marvin.d.miller
Nov 13, 2015 10:50 AM
jagtoes
Jul 28, 2014 02:41 AM
XJL
Mar 27, 2012 02:24 PM
