First timer in the XJ8 Forum
Old May 5, 2011 | 01:51 PM
BobC's Avatar
Default First timer in the XJ8 Forum
Hi fellow enthusisasts:
Does any one know what causes an intermittent jerky change from 1st. gear to 2nd gear in an automatic transmission?
Thanks a bunch for your help.
BobC
2004 XJ8 4.2VDP 83,700 miles
Old May 5, 2011 | 02:17 PM
user 2029223's Avatar
Banned
This is a common complaint. The good news is that you can probably cure it 80% of the time by changing the transmission fluid and filter. Go with Mobile 1 ATF and get it done by an experienced indie shop. It's not that big a deal and there are plenty of threads on the subject if you do a search. In fact there are quick links in the FAQ section.
Pay no attention to the Jag recommended service fluid and intervals.
Many of our members, the ones with average or better shade tree skills, have done it themselves.
Keep us posted on how it turns out.
Old May 6, 2011 | 09:09 PM
norisan's Avatar
I had a similar problem and it was completely cured by a re-flash of the transmission, I believe the dealer charged about $200.
Old May 7, 2011 | 08:39 AM
BobC's Avatar
Thanks guys. I had the transmission serviced and it does seem to have cured the problem. Appreciate your help.
Old May 7, 2011 | 10:58 AM
Banned
Previous reports were that performance continued to improve for several days after the service . Do get back to us on that aspect and do let us know what ATF fluid you chose.
Old May 7, 2011 | 04:43 PM
Fraser Mitchell's Avatar
I get this sort of thing ocasionally with mine, especially when I have just stopped dead to make a turn across traffic, then need to move quickly to make the turn. I can get a real clonk in these circumstances, but I have to say at the moment I just accept it as a characteristic, as I had similar with the Jatco box in my previous car, a Rover 75.
Old May 9, 2011 | 03:32 PM
BobC's Avatar
Tarheal:
Performance seems to have improved. No more jerky changes between 1st and 2nd gear. But it's been just a few days since the service, so it maybe too early to really say that the problem has been fixed.
I bit the bullet (as is customary in Texas) and went with the Jag original synthetic transmission fluid. Silly me! It was dreadfully expensive. But I may just have saved a very expensive repair.
Old May 9, 2011 | 04:02 PM
Banned
Sounds to me like a home run, even if you did get hosed on the ATF fluid.
Happy motoring.
Old May 10, 2011 | 11:56 AM
BobC's Avatar
Thanks Tarheal. Stay away from those gators in FL.
dsnyder586
Dec 29, 2024 07:39 PM
SteveSheldon
UK & Eire
505
Jul 14, 2016 04:48 AM
TexasCat
Sep 8, 2015 04:36 AM
jimbo1948
Sep 7, 2015 03:14 AM
