Found air spring issue...Need the fix!
Old Jul 23, 2016 | 11:36 AM
viper1996's Avatar
Default Found air spring issue...Need the fix!
Ok I did rear lower control arm bushings this week...After finishing it looked like the RR was low and sometimes OK...Now after a few days I start the car in park, and bounce the back end and the rear suspension goes right up about a half inch. As soon as it goes up the RR drops down that half inch in about 8 seconds and stays there...Left rear holds fine...There are no lights or warnings on the dash and the front works fine...So I am guessing it must be a leak from the tank line (red) to the airspring or the connections or the spring itself...How can I test the system if the pressure is not holding? Thanks
Old Jul 23, 2016 | 12:42 PM
jackra_1's Avatar
What about the height sensors? Did you by chance move one with the work you did?
If the corner sits 1/2" low and you dont hear the pump maybe the car thinks it has the correct height?
Old Jul 23, 2016 | 12:54 PM
viper1996's Avatar
Thanks Jackra...I was on my way home and started thinking the same thing...The pump is not running continually like you mentioned...Do you know if I need to tweak the leveler bracket up or down to raise the suspension???
Old Jul 23, 2016 | 01:43 PM
jackra_1's Avatar
To raise the suspension I believe you tweak it down. By tweaking it down the computer will think it is too low and raise that corner.
Old Jul 24, 2016 | 02:36 PM
Fraser Mitchell's Avatar
The correct way to adjust suspension height is using the correct calibration software on a lap-top plugged into the diagnostics socket and measure actual heights then follow the instructions. I had to have this done some time ago and no problems since. It was done at a local Jaguar independent.
Catsgame
Mar 30, 2016 01:05 PM
Ntimd8
Mar 29, 2016 02:16 PM
DanielSWE
Mar 28, 2016 06:22 AM
Jul 28, 2014 07:18 PM
warekito
Aug 9, 2007 10:02 AM
