front caliper rebuild
Old Sep 8, 2021 | 09:34 AM
mhamilton's Avatar
Default front caliper rebuild
Anyone know if there's a good quality caliper rebuild kit for the non-Brembo brakes? I looked at ATE's web site, but they don't know anything for the x350.
I noticed my front left wheel accumulates way more brake dust than the other, and the caliper itself has been discolored (rusty) since I got the car (10 years ago). It's definitely not sticking full time, maybe only under certain conditions. No discoloration on the rotor.
Old Sep 8, 2021 | 10:28 AM
arctic_man's Avatar
You could check RockAuto or your local auto store for parts. I have used Centric and BrakeBest before and have been happy with the quality. If it were me with non brembo brakes I would just replace the whole caliper. It has to come out anyway to rebuild it. Having rebuilt calipers, it can sometimes be a pain to get the pistons out or the new dust shields back on. However, the price savings is decent.
But if you do decide to rebuild, I would probably do both the fronts. Parts are dirt cheap and you will have to do a partial bleed anyway.
Old Sep 8, 2021 | 10:22 PM
xalty's Avatar
it’s like $1 on rock auto. or you can buy the genuine stuff for 10 times the price
https://www.turnermotorsport.com/p-3...t-priced-each/
Old Sep 9, 2021 | 01:30 PM
mhamilton's Avatar
Thanks, that link helps. I've since found Jaguar sells the seal/boot kit under C2C27274 for $50+. I did see the $1 kit on Rockauto, but I'll pass on that unless it comes from ATE. One thing I would like but haven't found is the piston itself. Will check the pad wear and slide pins before I do anything else. Nothing has indicated this side is sticking regularly--no pulling, no overheating pads, bearing, etc. But it most definitely accumulating more dust and for whatever reason has a rusty caliper while the others all still have the OE silver coating.
sawduster
Jan 13, 2023 08:49 AM
Tibow
Jun 20, 2019 08:36 AM
simo5555
Aug 27, 2015 07:50 PM
bigcatdaddy99
Aug 9, 2014 01:54 AM
jp3872
Apr 23, 2014 07:40 PM
