Front passenger window problem
Old Aug 29, 2020 | 09:28 PM
Paul Mason's Avatar
Default Front passenger window problem
Yesterday, I had all the windows and the roof open. When I tried the all-in-one closing feature with the door key, the passenger side front window would not close. Today, I got it to close in increments of about 2in by repeatedly disconnecting the battery and reconnecting. After maybe 5 times of reconnecting the battery, getting the window to close a couple of inches more each time and then disconnecting, I got the window fully shut. Playing around with it a bit, if I attempt to open it, it will go down a couple of inches and then stop. I then have to disconnect the battery to close it again. Does anyone have a suggestion of how to get the window working properly again? It seems like this might be a switch or electronic module issue??
Paul.
2004 X350
Old Aug 30, 2020 | 02:43 PM
Rickkk's Avatar
Personally, I would tend not to open/close the windows any more than need be. If it were me, I would check the voltage across the front passenger side power window motor as it sort of sounds to me like that motor may be failing.
Old Aug 30, 2020 | 04:59 PM
Six Rotors's Avatar
More likely to be the window regulator mechanism---especially if your vehicle has lived in salty winter environment. The cables can and do rust and eventually break. There are numerous threads if you use the search function.
Old Sep 3, 2020 | 03:10 PM
Paul Mason's Avatar
Hi Rickkk. I got into it today. I think you may be right in that the motor is failing. I removed the motor from the rest of the regulator mechanism, and it will not rotate continuously even when completely unloaded. I'm hoping to find cheap replacement on ebay. Thanks Paul.
Old Sep 3, 2020 | 03:16 PM
Paul Mason's Avatar
Surprisingly, since i live in upstate NY, the cables are not in bad conditiion. It did take a bit of a heave though to push the window up manually, which improved a bit after dousing the runners and cables with silicon spray. I'm into it now, so I'm going to get a beer and see if I can do anything with the motor, which I think may be the culprit in this case. Thanks!
Old Sep 3, 2020 | 04:00 PM
Rickkk's Avatar
You're more than welcome Paul. Anything to oblige.
Old Sep 3, 2020 | 05:10 PM
Wingrider's Avatar
Is there a place that repairs electric motors around where you live?
Old Sep 15, 2020 | 10:32 AM
Paul Mason's Avatar
Just to finish up this thread, I got my ebay window regulator, which originated from a car with around 66,000 miles - about 95k less than mine! It was a pretty easy fit and I gave the moving parts a good shot of silicon spray before I closed everything up. The window now works well. Thanks to everyone who provided advice on this.
Paul.
draganapiazzola
Aug 6, 2016 07:07 PM
clawsrout
Nov 20, 2013 08:35 AM
tomtomterrific
Jun 4, 2011 06:45 PM
RichmondXK
May 22, 2011 12:06 PM
rrgoldstein
Nov 26, 2009 08:48 AM
