Fuel Pump Voltage, XJR
Old May 9, 2019 | 01:48 AM
paddyx350's Avatar
Default Fuel Pump Voltage, XJR
Anybody know what voltage is applied to the fuel pumps for an XJR?
Is is constant? I know that the pumps are variable speed and controlled using a PWM signal from the REM and additional fuel pump module for the XJRs second pump.
Old May 9, 2019 | 04:29 PM
abonano's Avatar
Full battery voltage I believe. At least 10.5V for sure.
Old May 10, 2019 | 08:36 PM
meirion1's Avatar
There will be pin out tests in one of the manuals but I can't tell you exactly where.
These should quote voltages.
Old May 12, 2019 | 01:16 AM
paddyx350's Avatar
The pin point tests don't give an expected voltage
I'm going to back probe with the engine running and see what I get for the left and right hand side pumps
I'm doing the pin point tests now for the wiring between the ECM and the REM and Pump Module 2 but have come across the 5 point torx on the ECM connector, so will have to get one of these before proceeding any further.
Silo
Jan 21, 2019 05:03 PM
webbeing
Aug 18, 2018 10:49 PM
sdw96
Mar 14, 2018 06:39 PM
Supercale
Oct 21, 2017 07:27 PM
car5car
May 18, 2016 05:16 AM
