Fuse box location
Old Nov 29, 2021 | 08:35 PM
Bob Hornby's Avatar
Default Fuse box location
My X350 air conditioning has stopped, it looks like the fan is not working as no air is emitting from the vents. So the first thing I should check is the fuse, but where the devil is the CABIN FUSE BOX ? I would expect it to be somewhere under the dash, but cannot see it or any panel to pull down. Help needed.
Old Nov 29, 2021 | 09:11 PM
xalty's Avatar
right hand kick panel. usually this failure is the blower motor resistor
the upgraded part is significantly more expensive so just buy the original. hella 3153721764
Old Nov 29, 2021 | 09:34 PM
Bob Hornby's Avatar
Thanks Xalty, the fuse looks good, so where is the resistor?
Old Nov 29, 2021 | 09:39 PM
xalty's Avatar
https://www.jaguarforums.com/forum/x...er-quit-62390/
Old Nov 30, 2021 | 01:05 AM
Bob Hornby's Avatar
Thanks again Xalty, it looks a fair bit more involved than I anticipated.
Old Nov 30, 2021 | 06:11 PM
Wingrider's Avatar
Not that a bad a job, take your time, read the instructions, ask questions.
Old Nov 30, 2021 | 07:00 PM
Bob Hornby's Avatar
Thanks Wingrider, I am searching to see if I can find a module in Australia as to get one from overseas could take up to a couple of months and we are just starting our summer and A/C is almost mandatory.
Old Dec 1, 2021 | 04:59 PM
meirion1's Avatar
It will be repairable with a new power transistor and/or thermal fuse.
If you are interested let me know a I will see if I can find my post which
I wrote many years ago on the UK forum.
Old Dec 1, 2021 | 07:18 PM
Bob Hornby's Avatar
Thanks Meirion, If I can locate a module then I will be doing the job. The directions from Xalty look comprehensive, however if you can find your wright up I would appreciate it as you can never have too much information.
Old Dec 1, 2021 | 09:04 PM
Bob Hornby's Avatar
Does anyone know when Jaguar changed over to the updated control module from the initial problematic one? my car is a 2006 build.
Old Dec 2, 2021 | 03:45 AM
meirion1's Avatar
https://www.jaguarforums.com/forum/x...owners-107021/
https://www.jaguarforums.com/forum/x...t-62390/page2/
I can't find my original post on the UK forum.
It was in 2008! and I think it's gone into the archives permanently.
Old Dec 3, 2021 | 04:52 PM
Bob Hornby's Avatar
I have found and ordered a module from the main Jaguar/LandRover dealer. It has to be shipped from Melbourne so by mid next week things should be cool once again.
Old Dec 4, 2021 | 09:48 PM
Bob Hornby's Avatar
Whilst I am awaiting my new module to arrive I thought I would tackle the job of glove box removal. So a couple of questions.
1. I am guessing I do not need to take off the glove box lid. Is this correct?
2. The diagram/instructions in the workshop manual (item 2) instructs to "Reposition the glove box compartment shelf" with a picture showing it. My glove box does not have this shelf so do I just disregard this bit?
3. Just confirming the screws to be removed circled in the photo (and 2 more on the other side) and the small one arrowed.
4. Item 5 in the manual states to remove screws from the upper part of the glove box. I am assuming they are inside the box but mine are missing. There are 4 holes where it looks like screws should be but are missing (taken off sometime ago and not replaced?) But the diagram shows 5 screws and bolts, where are the bolts?
I am a bit nervous about doing this job.
Old Dec 5, 2021 | 01:48 PM
Wingrider's Avatar
There is, or was a shelf inside the glove box.
I don't remember removing the lid.
Just follow the instructions, & find ALL the fasteners.
Getting it out, & back in is a bit of a pain, just be patient.
It will come out, & go back in, the insulation on mine, didn't survive though.
JagQ
Aug 29, 2019 11:33 AM
lenavarrete
XJ40 ( XJ81 )
Jul 20, 2018 11:33 PM
mrtalkradio
XJ40 ( XJ81 )
Feb 24, 2012 05:36 PM
nairnman
Nov 10, 2010 05:03 AM
Sovereign_ty
XJ40 ( XJ81 )
Dec 30, 2007 06:40 PM
