Gas milage 05 xjr
Old Jun 15, 2010 | 08:19 AM
user 2029223's Avatar
Banned
Default Gas milage 05 xjr
I just got back from 1200+ mile run up to NC and back. The outside temp was 95 degrees + on the run up and a max of 103 degrees on the return trip. The car ran flawlessly and delivered 28.4 MPG on both legs, accordingly to the trip computer.
I did not know the car was capabile of this kind of performance. The speed limit varied between 55 and 75 MPH the whole way and I usually set my cruse control at 5 MPH over the posted limit.
I took a similar run at Christmas and got 27 and change MPG. The only difference back then was Cold weather and I have sense switched to Mobile 1 synthetic in the engine and transmission.
What do you think?
Old Jun 15, 2010 | 11:12 AM
Drew's Avatar
I get about 24-26 on the highway with my 04 XJR. I drive about 75 and do have a heavy foot from time to time. City is between 17-18. I have found the computer to be off by as much as 1 MPG.
Old Jun 15, 2010 | 02:36 PM
Banned
Reletive to computer milage data, I have found the same optimistic error in every car so equiped, regardless of make. It's a small chore to do the calculation by pen and paper, so I just go along with the game. Still-- 28 MPG and change even allowing for the computer fib is empressive.
The thing that really got my attention was the full 1 mile per gallon in hot weather over cold weather. I wonder if anyone has compareable data with synthetic fluids vs mineral fluids?
Old Jun 15, 2010 | 04:26 PM
Drew's Avatar
Every car I have drove always gets worse GPM is cold weather. I have always wondered why? Didn't know if it's denser air, the car chokes longer because of warm up time or the fact I let my car runs for 1-3 minutes before I drive.
Old Jun 15, 2010 | 04:52 PM
hlgeorge's Avatar
In my naturally aspired XJ8, I regularly get 29-31 MPG on the freeway.
Old Jun 15, 2010 | 09:23 PM
gdcont's Avatar
Default Gas mileage
The diference is "summer and winter grade" gas. One is more volatile then the other. I believe the summer is more than the winter grade.
Old Jun 15, 2010 | 09:45 PM
meirion1's Avatar
Default Mpg
In Australia the speed limit is 100K/HR ie 62 mph and if I reset the computer when I am actually on the freeway and drive on cruise set to the speed limit, I have recorded 41MPG!!! over about a 30mile run.Incredible.
Old Jun 16, 2010 | 01:02 PM
Drew's Avatar
WOW! is that downhill? haha
Old Jun 16, 2010 | 01:51 PM
williamsinhb's Avatar
Yeah - I am pleasnatly surprised that I get 26 mpg driving 75 - 80 mph (with an occaisional burst to 100). And yes I get 18 mpg city.
Old Jun 17, 2010 | 07:56 PM
Banned
Another thing about my 1300 mile road trip. I drove the hell out of my 05 XJR with 51,000 miles on the meter and only used 1/2 qt. of oil. This in 95 to 103 degree heat with Mobile 1 synthetic oil. You can't complain about that.
Damn, I love these cars.
Old Jun 18, 2010 | 10:42 AM
Drew's Avatar
I have noticed they do burn some oil. I don't know if the engine was just designed that way or other. Mine burns about 1/2 qt. per oil change and the last one had about 4,200 miles on it.
Old Jun 18, 2010 | 08:12 PM
hlgeorge's Avatar
My oil has always remained constant between oil changes. I'm using Castrol Syntec.
XJsc-guy
Nov 23, 2015 01:56 PM
Papelione
Sep 21, 2015 06:13 PM
pab
Sep 16, 2015 10:34 AM
tsimms7
Sep 15, 2015 12:43 PM
Ipc838
Sep 13, 2015 03:27 PM
