Gear selector trouble
Old Nov 21, 2022 | 05:15 AM
Mclovin22's Avatar
Default Gear selector trouble
Hello all,
Wanted to make a post about some trouble I'm having with my gear selector in my 2007 XJ8. First time I've experienced this sort of thing. Was coming out from the store, got in the car and started it with no problem. Went to put it into gear and there was a lot of resistance trying to put the gear selector into drive. Normally don't have such a problem as it's silky smooth. I made a post on the book of the face and have received some help. Was told to check the bracket on the left side of the transmission that has 2 8mm bolts and check to see if it was tight. I have done so and alas the problem still remains. There was also mention on taking apart the wood trim by the gear selector, and to bypass the solenoid with a small screwdriver to rotate the plastic gear on the left side of the shifter assembly. I've had trouble trying to bypass this solenoid and was told I might as well replace the entire assembly as the cost of replacing the solenoid would be the same as the assembly. Someone apparently even removed it but I'm not quite sure the best way to go about this.
Any advice is appreciated, as I've already got the wood trim removed and am just trying to get the Jag right again.
Old Nov 28, 2022 | 05:19 PM
OldKarz's Avatar
Originally Posted by Mclovin22
Hello all,
Am I interpreting this correctly - You can move the lever to the gears but it is stiff? You need to find what is causing the stiffness. Let the bracket on the transmission go and try moving the lever. Then move the lever on the transmission by hand. If both are free, with the bracket lose, then the stiffness is in the cable. Could be a broken strand jamming internally.
mrs_sutsie
XF (X260)
May 12, 2023 01:47 PM
Fad-Jag
XF (X260)
Sep 3, 2020 07:22 AM
Rogelio Serrano
Dec 4, 2016 10:50 AM
crt_ben
22
Mar 6, 2015 05:50 AM
Scottyobmu
Sep 20, 2009 08:02 AM
