Gearbox fault on 09 VDP
Old Feb 8, 2021 | 08:36 PM
Peterinio's Avatar
Default Gearbox fault on 09 VDP
It's cold today in Ontario Canada and my cat has been sitting for about 5 days without running. As is usual for a sitting jag the battery needed a boost to start. After getting on the highway I realized it seemed to be stuck in about 3rd gear and there was a "Gearbox Fault" message. I tried stopping, putting gear into park and so forth several times but no change. The battery is a little over a year old so it would not seem to be that. Does anyone know if this is a known issue? It hasn't happened to me before though and so I wonder if the cold has anything to do with it.
Thanks.
Peter
Old Feb 9, 2021 | 08:43 AM
Wingrider's Avatar
Only a guess at best;
Could the level of trans fluid be low, along with the cold ?
Old Feb 9, 2021 | 10:10 AM
Peterinio's Avatar
if only there was a dipstick....
Old Feb 9, 2021 | 11:09 AM
Wingrider's Avatar
If your aunt had *********, she'd be your uncle, get busy and check.
PIA i know but what else can you do?
Old Feb 9, 2021 | 04:05 PM
Peterinio's Avatar
Warmed up today and seems ok. Probly needs a flush.
Peter
Old Feb 10, 2021 | 10:48 PM
kg74's Avatar
What are your miles? Have you changed the filter, dropped the valve body and replaced the various rubber seals that go bad?
If you have no visible leaks your fluid level should be fine. Check you transmission lines near the radiator as these are a weak point and leak.
Old Feb 11, 2021 | 06:31 PM
Andrew Stump's Avatar
If you think checking the level is a PIA, just wait until you have to replace those trans lines.
Old Feb 11, 2021 | 07:17 PM
Wingrider's Avatar
Read replacing just the rubber portion of the lines, saves time, effort, and money.
The lack of a dipstick is not a good idea.
Changed the filter, & fluid, with no fluid loss afterwards, i don't really miss it.
enderle
I-Pace EV
Sep 22, 2020 03:40 PM
04jag
Mar 9, 2020 07:07 PM
jaguarXFsupercharged_XFR 500HPclone
Feb 6, 2019 06:47 PM
Sulli
Dec 26, 2018 02:24 AM
meaculpa
Feb 20, 2013 09:09 AM
