Gearbox Fault
Old May 14, 2016 | 12:48 PM
Vicious's Avatar
Default Gearbox Fault
Hello all, I'm having issues with my 2004 X350 transmission. It was shifting very hard and making a metalic sounding thud when shifting at freeway speeds.
I took it in and had the service done, fluid and filter change along with re-flashing the TMC. Now i'm getting a gearbox fault message on the dash.
Help please.
Vicious in Phoenix Arizona USA
Old May 14, 2016 | 01:01 PM
pkoko's Avatar
Does the car drive and shift? Did you remove the codes?
Old May 14, 2016 | 02:56 PM
Vicious's Avatar
Yes and Yes
Old May 14, 2016 | 07:10 PM
abonano's Avatar
Help please.
Was fluid level checked properly at 40 deg C with car level?
Additionally, what software version did you use to reflash the TCM? Also, were adaptations cleared? PCM reflashed??
There should be code(s) in the TCM, pull them and post here.
Old May 14, 2016 | 08:36 PM
Vicious's Avatar
Don't know the answers.......I took it to an indy shop for the service. I will ask them to answer your questions on Monday when they are open for service.
Old May 18, 2016 | 04:18 PM
Vicious's Avatar
Just wanted to post that I had two times where the dash message read "Gearbox Fault" so I'm having the transmission rebuilt from top to bottom at a local shop.
Thanks to everyone who replied and helped out with information.
Vicious
al_roethlisberger
Jul 16, 2024 04:19 PM
cyber3d
Mar 15, 2017 12:04 PM
damienedwards
Dec 20, 2016 12:02 PM
saltyraoul
Apr 18, 2016 06:53 PM
nasa25
Apr 17, 2016 09:57 AM
